RockPro64 not coming online after reboot
(08-02-2019, 08:09 AM)martinayotte Wrote: Are you sure that the eMMC is "completely blank" ?
If there is some kind of u-boot present in the boot sectors, it can be the cause of boot hanging ...
You can erase those boot sectors using "dd if=/dev/zero of=/dev/mmcblk2 bs=1024 count=1000" and try again to boot from SDCard.
Ah you are correct, if I write 0's to the eMMC I can boot from the SD card and then successfully run the `reboot` command with both eMMC and SD card present.
So the hanging after `reboot` command issue only occurs when the eMMC module with a boot sector is present.
One option could be keeping the /boot on the SD while leaving root partition on eMMC to get the best of both worlds (eMMC speed and a machine that can reboot).
However, since the board and eMMC are newly purchased, I am wondering if I should pursue an RMA with the vendor (AmeriDroid). Part of me thinks that it is not a hardware issue since I have seen the same issue from others as well, but it might be worth a shot to narrow this down?
RE: RockPro64 not coming online after reboot - by imapc99 - 08-02-2019, 02:44 PM
  Installing Wifi drive for the RockPro64 John45595 0 343 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 813 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 709 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,332 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 928 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,371 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,887 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,735 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,040 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,845 10-21-2022, 07:44 AM
Last Post: rapier1
