Preinstalled Debian version?
#21
(07-26-2019, 04:25 AM)Luke Wrote:
(07-25-2019, 08:08 PM)RMJ250 Wrote:
(07-25-2019, 12:19 PM)Luke Wrote:
(07-25-2019, 10:15 AM)tophneal Wrote: I'm curious, since there appear to be a few options, what version/iteration of Debian has been chosen as the default OS for the PBP?
Debian 9.9. A lot of custom work has gone into this image, so there really wasn't time to update it for Buster.
Here is the image: https://github.com/mrfixit2001/debian_desktop/releases
I'm guessing at some point Debian 10 will be available? Any ideas how long that would be? (1st batcher for PBP, I am no dev but willing to test if I can)
Thx
J
At some point. You can upgrade to Buster manually, but it will break a number of things. If you're interested in figuring out how to fix everything that the upgrade breaks - document it - and share it, then that would be great.
I upgraded manually, and while most things worked, it was noticeably slower.  There was also a drm library conflict that caused the upgrade to fail.  I had to force a purge of the conflicting package before I could complete the upgrade.
In the end I restored the stretch version.  I don't feel like putting in the work to make it work well so I'll just wait Smile
Matthew
Preinstalled Debian version? - by tophneal - 07-25-2019, 10:15 AM
RE: Preinstalled Debian version? - by Luke - 07-25-2019, 12:19 PM
RE: Preinstalled Debian version? - by RMJ250 - 07-25-2019, 08:08 PM
RE: Preinstalled Debian version? - by Luke - 07-26-2019, 04:25 AM
RE: Preinstalled Debian version? - by m80 - 11-04-2019, 09:01 AM
RE: Preinstalled Debian version? - by Chjo83 - 08-24-2019, 11:21 AM
RE: Preinstalled Debian version? - by CampGareth - 08-24-2019, 12:20 PM
RE: Preinstalled Debian version? - by Luke - 08-24-2019, 02:25 PM
RE: Preinstalled Debian version? - by ac8dg - 08-27-2019, 07:15 AM
RE: Preinstalled Debian version? - by Luke - 08-27-2019, 08:23 AM
RE: Preinstalled Debian version? - by ASIC - 09-22-2019, 12:41 PM
RE: Preinstalled Debian version? - by u974615 - 11-13-2019, 05:33 PM
RE: Preinstalled Debian version? - by Luke - 11-13-2019, 06:04 PM
RE: Preinstalled Debian version? - by u974615 - 11-14-2019, 11:15 AM
RE: Preinstalled Debian version? - by RMJ250 - 07-26-2019, 09:39 PM
RE: Preinstalled Debian version? - by doc1623 - 08-18-2019, 06:59 AM
RE: Preinstalled Debian version? - by hmuller - 08-18-2019, 07:19 PM
RE: Preinstalled Debian version? - by CampGareth - 08-18-2019, 11:50 PM
RE: Preinstalled Debian version? - by u974615 - 08-22-2019, 04:09 PM
RE: Preinstalled Debian version? - by sjk - 08-24-2019, 07:16 AM
RE: Preinstalled Debian version? - by z4v4l - 09-22-2019, 02:26 PM
RE: Preinstalled Debian version? - by Solra Bizna - 11-03-2019, 10:23 AM
RE: Preinstalled Debian version? - by ac8dg - 11-04-2019, 02:08 PM
RE: Preinstalled Debian version? - by embhorn - 11-04-2019, 04:20 PM
RE: Preinstalled Debian version? - by zaius - 11-05-2019, 01:22 PM
RE: Preinstalled Debian version? - by ac8dg - 11-05-2019, 03:29 PM
  Debian on Pinebook Pro u974615 7 1,117 03-31-2024, 10:11 AM
Last Post: u974615
  install debian on pbp jsch 7 4,107 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,525 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,101 07-15-2023, 02:58 PM
Last Post: u974615
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,287 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,352 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,059 10-19-2022, 03:09 AM
Last Post: alpopa
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 1,922 09-23-2022, 08:37 PM
Last Post: computerc
  Debian emmc installer db579 6 3,014 08-23-2022, 06:13 AM
Last Post: db579
  PBP won’t boot from eMMC after Debian update / Tow-Boot installer won’t boot from SD Pino64 21 10,383 05-12-2022, 05:00 AM
Last Post: Pino64
