U.FL plug on the Wifi/BT module?
Bonjour ...
Quelqu'un a-t-il acheté un connecteur WiFi pour le RockPro64 avec un connecteur RP-SMA !?
Celui ou Ceux qui en ont trouvé un, où l'ont-il acheté !?
D'avance, Merci pour vos réponses.
Cordialement, David.
Hello ...
Has anyone purchased a WiFi connector for the RockPro64 with a RP-SMA connector !?
The one or Those who found one, where did they buy it !?
In advance, thank you for your answers.
Best Regards, David.
U.FL plug on the Wifi/BT module? - by domih - 06-07-2019, 06:43 PM
RE: U.FL plug on the Wifi/BT module? - by tllim - 06-13-2019, 06:53 PM
RE: U.FL plug on the Wifi/BT module? - by domih - 06-14-2019, 08:05 PM
RE: U.FL plug on the Wifi/BT module? - by dml-pc - 06-30-2020, 08:33 AM
RE: U.FL plug on the Wifi/BT module? - by dml-pc - 08-11-2020, 11:17 AM
RE: U.FL plug on the Wifi/BT module? - by dml-pc - 02-17-2021, 02:24 AM
RE: U.FL plug on the Wifi/BT module? - by dml-pc - 09-23-2021, 09:27 AM
  AW-CM256SM wifi card mtek 4 2,372 10-30-2023, 12:00 PM
Last Post: diederik
  Pine Wifi Module williamdieter 2 2,794 07-20-2022, 03:31 AM
Last Post: imianz
  To Wifi or To Bluetooth, That is the Question WarpLover 0 1,586 07-06-2021, 08:45 PM
Last Post: WarpLover
  RP64 TV box case with wifi Wizzard 2 3,307 03-10-2021, 12:23 AM
Last Post: Wizzard
  OpenWRT + Intel I350-T4 + 1x1 Dual Band WIFI pi64 0 2,036 11-17-2020, 04:25 AM
Last Post: pi64
  new WIFI/BT module not working with android 8.1 Firesped 0 2,034 05-12-2020, 10:33 PM
Last Post: Firesped
  Questions about the ROCKPro64 1x1 Dual Band WIFI module thelabratrules 0 2,018 04-04-2020, 03:29 PM
Last Post: thelabratrules
  Best location for adhesive wifi antennas with NAS case callegar 1 3,074 02-17-2020, 12:40 PM
  No WiFi f4exb 3 5,035 11-11-2019, 05:54 AM
Last Post: winstar
  Need to add various Wifi chipset support slappymcphee 6 8,144 08-15-2019, 05:26 PM
Last Post: evilbunny
