OpenWRT + Intel I350-T4 + 1x1 Dual Band WIFI
i want to substitute my current AP with a RockPro64, a quadport Intel I350-T4 PCIe card and the 1x1 Dual Band Wifi Module. It should run the current OpenWRT version.
  • Is this setup/configuration stable or will it encounter the PCIe controller hardware error handling bug?
  • Does the official OpenWRT release run out of the box with this setup or do i have to compile it by my self?
  • Does the quadport card fit into the NAS case?
Many thanks in advance for your replies.
Sincerly
  pi64
  AW-CM256SM wifi card mtek 4 2,293 10-30-2023, 12:00 PM
Last Post: diederik
  U.FL plug on the Wifi/BT module? domih 8 12,702 10-17-2022, 04:43 AM
Last Post: callegar
  Pine Wifi Module williamdieter 2 2,726 07-20-2022, 03:31 AM
Last Post: imianz
  To Wifi or To Bluetooth, That is the Question WarpLover 0 1,562 07-06-2021, 08:45 PM
Last Post: WarpLover
  zfs on rockpro64 - any dual nvme PCI adapter for software raid ? romadr 0 1,916 04-22-2021, 02:59 PM
Last Post: romadr
  RP64 TV box case with wifi Wizzard 2 3,269 03-10-2021, 12:23 AM
Last Post: Wizzard
  new WIFI/BT module not working with android 8.1 Firesped 0 2,006 05-12-2020, 10:33 PM
Last Post: Firesped
  Questions about the ROCKPro64 1x1 Dual Band WIFI module thelabratrules 0 1,996 04-04-2020, 03:29 PM
Last Post: thelabratrules
  Best location for adhesive wifi antennas with NAS case callegar 1 3,038 02-17-2020, 12:40 PM
  PCI-e to Dual SATA-II Interface Card only works with one disk taube 4 4,466 12-27-2019, 10:42 AM
Last Post: taube
