RP64 TV box case with wifi
I am planning to get some RP64 case to use as some TV box, but I prefer wifi over LAN connection. Is there any case that supports internal wifi adapter? I wanted this, but not sure how it will handle the wifi adapter.
https://pine64.com/product/rockpro64-pre...num-casing
I give it up, I ordered both aluminium and ABS case, will try which one is better.
So, I was quite surprised that wifi works even with that alumunium case with the receiver inside the case Smile
  AW-CM256SM wifi card mtek 4 10,063 10-30-2023, 12:00 PM
Last Post: diederik
  RP64 Won't Boot After Power Down ColPanic_ 10 18,756 06-27-2023, 07:31 AM
Last Post: dkebler
  U.FL plug on the Wifi/BT module? domih 8 20,118 10-17-2022, 04:43 AM
Last Post: callegar
  Pine Wifi Module williamdieter 2 7,355 07-20-2022, 03:31 AM
Last Post: imianz
  NAS case HDD power cable failure (buck failure) ashleymills 1 4,301 04-01-2022, 11:25 AM
Last Post: ashleymills
  Plugging In Case Fan and CPU Fan publiclewdness 0 2,831 01-04-2022, 09:58 AM
Last Post: publiclewdness
  Nas Case out of stock Goffi 2 4,611 12-04-2021, 05:14 AM
Last Post: Goffi
  To Wifi or To Bluetooth, That is the Question WarpLover 0 3,057 07-06-2021, 08:45 PM
Last Post: WarpLover
Question 1U Rackmount Case for ROCKPro64 tuaris 3 8,613 02-18-2021, 08:09 PM
Last Post: TRS-80
  NAS Case: Issues with hardware installation, esp. screws kuleszdl 0 3,291 01-09-2021, 05:24 PM
Last Post: kuleszdl
