NAS Case: Issues with hardware installation, esp. screws
Hi folks,
I just assembled my NAS case for the RP64 which I had lying around for a few months. When doing this, I followed the wiki, yet I encountered a few obstacles:
(1) The wiki shows the RP64 screwed in with black screws. This does not seem right to me. Imho, the black screws with the cone heads go only on the outside of the case. For inside the case, the four silver screws with the flat heads seem right to me.
(2) The edges of the cage for the HDDs are pretty sharp and might damage the SATA/Power cables while routing. I have put some tape  around the sharp parts to make it more safe. Would you consider this a worthwhile recommendation for the wiki?
(3) The larger silver screws included for installation of the hard drives seem too long to me. When I used them, I damaged the threads in one of my disks although I paid attention not to tighten them too hard. Luckily I tried this with two near-worthless and very dated disks (250 GB WD RAID Edition, the "original" and legendary predecessors of the WD Red series...). I then switched the screws for some others I had here that are about half way shorter and seem to fit better.
Has anyone else had similar issues? If I'm not the only one I will consider updating the wiki and adding some notes about these issues.
  Issues with several boards geekboy01 0 2,843 04-05-2023, 05:58 PM
Last Post: geekboy01
  NAS case HDD power cable failure (buck failure) ashleymills 1 4,152 04-01-2022, 11:25 AM
Last Post: ashleymills
  Plugging In Case Fan and CPU Fan publiclewdness 0 2,693 01-04-2022, 09:58 AM
Last Post: publiclewdness
  Nas Case out of stock Goffi 2 4,436 12-04-2021, 05:14 AM
Last Post: Goffi
  RP64 TV box case with wifi Wizzard 2 5,890 03-10-2021, 12:23 AM
Last Post: Wizzard
Question 1U Rackmount Case for ROCKPro64 tuaris 3 8,437 02-18-2021, 08:09 PM
Last Post: TRS-80
  case for RockPro64 + PCI-E M.2 NVMe Card? AndyOfLinux 9 21,090 01-05-2021, 05:05 PM
Last Post: kuleszdl
  SATA issues machina 25 53,340 10-16-2020, 12:16 PM
Last Post: lrb
  Release CAD files for NAS case or parts of it? diizzy 5 10,133 08-13-2020, 04:50 AM
Last Post: diizzy
  Best location for adhesive wifi antennas with NAS case callegar 1 5,009 02-17-2020, 12:40 PM
