AW-CM256SM wifi card
Hello!
I've seen a couple of threads asking how to get the AW-CM256SM combo wifi/bluetooth module working, but I haven't seen any conclusive cases of a user getting it running yet.  I'm in the same boat myself, but I think I'm making progress towards it.
I'm using Manjaro for ARM, the image specifically for the RockPro64.  I installed brcmfmac from the Arch repositories using yay, as I believe that's the correct driver for the module.
"dmesg | grep SDIO" gives me this: "[     2.172676] mmc0: new ultra high speed SDF104 SDIO card at address 0001"
"dmesg | grep brcmfmac" returns the following:
[    8.602310] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    8.602862] usbcore: registered new interface driver brcmfmac
[    8.605626] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.pine64,rockpro64-v2.1.bi
n failed with error -2
[    8.614427] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.pine64,rockpro64-v2.1.tx
t failed with error -2
[    8.614570] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.txt failed with error -2
[    9.641432] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
If I am understanding correctly then, the module is being detected on mmc0, and I do have the driver installed, but something isn't configured correctly.  Any ideas on what I need to do next?
Thanks in advance!
Hi i have the same issue with SOquartz64 2GB+16Gb eMMc unit
any fix for the issue?
greetings
sorry the double post, but i done with:
sudo ln -sf /lib/firmware/brcm/brcmfmac43455-sdio.AW-CM256SM.txt /lib/firmware/brcm/brcmfmac43455-sdio.txt
sudo ln -sf /lib/firmware/cypress/cyfmac43455-sdio.bin /lib/firmware/brcm/brcmfmac43455-sdio.bin
sudo ln -sf /lib/firmware/cypress/cyfmac43455-sdio.clm_blob /lib/firmware/brcm/brcmfmac43455-sdio.clm_blob
sudo rmmod brcmfmac
sudo modprobe brcmfmac
dmesg
[ 7896.303895] usbcore: registered new interface driver brcmfmac
[ 7896.490453] brcmfmac_wcc: brcmf_wcc_attach: executing
[ 7896.504985] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Apr 15 2021 03:03:20 version 7.45.234 (4ca95bb CY) FWID 01-996384e2
nmctl show dev
GENERAL.DEVICE:                         wlan0
GENERAL.TYPE:                           wifi
GENERAL.HWADDR:                         E8:FB:1C:7F:48:A7
GENERAL.MTU:                            1500
GENERAL.STATE:                          30 (desconectado)
GENERAL.CONNECTION:                     --
GENERAL.CON-PATH:                       --
IP4.GATEWAY:                            --
IP6.GATEWAY:                            --
GENERAL.DEVICE:                         p2p-dev-wlan0
GENERAL.TYPE:                           wifi-p2p
GENERAL.HWADDR:                         (desconocido)
GENERAL.MTU:                            0
greetings
rockpro64 debian 12.2 bugfix was PERFECT - Thank you!
On a Debian (based) system, install firmware-brcm80211 package and then do this:
cd /lib/firmware/brcm/
ln -s brcmfmac43455-sdio.AW-CM256SM.txt brcmfmac43455-sdio.pine64,rockpro64-v2.0.txt
ln -s brcmfmac43455-sdio.AW-CM256SM.txt brcmfmac43455-sdio.pine64,rockpro64-v2.1.txt
That should be all you need.
Ref: https://git.kernel.org/pub/scm/linux/ker...a92193f2c6
  Which SATA card should I use my NAS server RAID5 Louysa 3 5,765 09-24-2023, 04:40 AM
Last Post: JPT223
  U.FL plug on the Wifi/BT module? domih 8 21,096 10-17-2022, 04:43 AM
Last Post: callegar
  Pine Wifi Module williamdieter 2 7,968 07-20-2022, 03:31 AM
Last Post: imianz
  Full Size Bracket for the NVME PCI-E Card publiclewdness 0 3,363 12-31-2021, 12:53 AM
Last Post: publiclewdness
  Rockpro64 Sata Card kills itself jerry110 33 77,790 10-20-2021, 04:36 AM
Last Post: fieni
  Right direction SATA card corax 2 6,659 09-15-2021, 12:46 PM
Last Post: corax
  To Wifi or To Bluetooth, That is the Question WarpLover 0 3,287 07-06-2021, 08:45 PM
Last Post: WarpLover
  Industrial memory card m.ekstrom 1 4,809 03-23-2021, 05:55 AM
Last Post: barray
  RP64 TV box case with wifi Wizzard 2 6,504 03-10-2021, 12:23 AM
Last Post: Wizzard
  Multiport Gigabit Card? jerry110 24 50,439 02-26-2021, 03:54 PM
Last Post: kuleszdl
