U.FL plug on the Wifi/BT module?
(06-07-2019, 06:43 PM)domih Wrote: Hello,
I bought an RP-SMA -> U.FL antenna for the Wifi/BT module.
The antenna pigtail UF.L plugs looks much bigger than the plugs on the original antennas coming with the Wifi/BT module (let's around 1.5 larger).
I checked the RockPro64 wiki as well as https://en.wikipedia.org/wiki/Hirose_U.FL and drew a blank.
Could you tell me what kind of plugs the Wifi/BT module uses?
TIA!
The ROCKPro64 Wifi/BT module using MHF4 connector not the U.FL type, info located at http://www.cmpter.com/single.asp?id=21
In future module, we plan to use back U.FL.
U.FL plug on the Wifi/BT module? - by domih - 06-07-2019, 06:43 PM
RE: U.FL plug on the Wifi/BT module? - by tllim - 06-13-2019, 06:53 PM
RE: U.FL plug on the Wifi/BT module? - by domih - 06-14-2019, 08:05 PM
RE: U.FL plug on the Wifi/BT module? - by dml-pc - 06-30-2020, 08:33 AM
RE: U.FL plug on the Wifi/BT module? - by dml-pc - 08-11-2020, 11:17 AM
RE: U.FL plug on the Wifi/BT module? - by dml-pc - 02-17-2021, 02:24 AM
RE: U.FL plug on the Wifi/BT module? - by dml-pc - 09-23-2021, 09:27 AM
  AW-CM256SM wifi card mtek 4 2,437 10-30-2023, 12:00 PM
Last Post: diederik
  Pine Wifi Module williamdieter 2 2,814 07-20-2022, 03:31 AM
Last Post: imianz
  To Wifi or To Bluetooth, That is the Question WarpLover 0 1,590 07-06-2021, 08:45 PM
Last Post: WarpLover
  RP64 TV box case with wifi Wizzard 2 3,333 03-10-2021, 12:23 AM
Last Post: Wizzard
  OpenWRT + Intel I350-T4 + 1x1 Dual Band WIFI pi64 0 2,043 11-17-2020, 04:25 AM
Last Post: pi64
  new WIFI/BT module not working with android 8.1 Firesped 0 2,043 05-12-2020, 10:33 PM
Last Post: Firesped
  Questions about the ROCKPro64 1x1 Dual Band WIFI module thelabratrules 0 2,024 04-04-2020, 03:29 PM
Last Post: thelabratrules
  Best location for adhesive wifi antennas with NAS case callegar 1 3,090 02-17-2020, 12:40 PM
  No WiFi f4exb 3 5,057 11-11-2019, 05:54 AM
Last Post: winstar
  Need to add various Wifi chipset support slappymcphee 6 8,200 08-15-2019, 05:26 PM
Last Post: evilbunny
