Blank Screen on Boot
More often than not, my Pinebook 11 boots to a blank screen (it turns off I believe). The green power led stays on. This happens after it shows
Starting Kernel...
on the screen. It then goes black and stays black. Doesn't seem to matter if the device is plugged in or not. Battery is nowhere near dead and this is very hit or miss. The next day it will just work, and later that day, it may not work again.
Had anyone else had this issue and if so, how did you fix it? Any suggestions?
Running Manjaro KDE. On the Manjaro ARM forums, they have not run into this problem before, making me wonder if it's a hardware issue with my unit... Sad
Blank Screen on Boot - by MECZero - 04-10-2019, 07:10 AM
RE: Blank Screen on Boot - by tllim - 04-15-2019, 03:43 PM
RE: Blank Screen on Boot - by MECZero - 05-09-2019, 07:38 PM
RE: Blank Screen on Boot - by MECZero - 05-10-2019, 05:57 AM
RE: Blank Screen on Boot - by tllim - 05-12-2019, 11:54 AM
  Latest images from different distros failing to boot from SD card jmonty42 2 4,274 11-17-2020, 09:32 AM
Last Post: pagesix1536
  pinebook black screen when booting with "different power mode than last used" penzoiders 12 19,159 04-27-2020, 06:27 AM
  Ethernet not found. error during boot Surehand53 1 3,125 07-24-2019, 05:00 AM
Last Post: ObviousHobbit
  Manjaro hangs on boot DAMO238 1 3,288 07-08-2019, 08:14 AM
Last Post: DAMO238
  Adding coherent_pool to boot.cmd on Xenial Mate by Ayufan causes boot loop k_mp 0 1,960 06-11-2019, 01:36 PM
Last Post: k_mp
  How to Configure Screen Brightness in mate on pinebook via terinal? shirman 6 9,105 12-02-2018, 05:37 AM
Last Post: mikee3000
  Pinebook Ubuntu XFCE screen resolution options Fox7799 2 4,473 12-01-2018, 06:05 PM
Last Post: Fox7799
  how do I boot to SD? (1080) tedder 7 8,341 11-16-2018, 03:15 AM
Last Post: Surehand53
  How to get text boot on KDE Neon maldus 5 6,902 11-13-2018, 04:29 AM
Last Post: maldus
  Dimmed screen too much in plasma boballen55 1 3,166 11-09-2018, 03:42 PM
Last Post: boballen55
