Ethernet not found. error during boot
Hi.
Every now and then when I boot from a SD card I get the error `Ethernet not found.` during the boot sequence and then I am in some shell.
After a power off/on booting eventually works.
I experienced that with more than one Linux, so I think it is not release specific.
Has anyone an idea what the reason could be?
(03-04-2019, 11:03 AM)Surehand53 Wrote: Hi.
since you haven't had anyone answer:
https://forum.pine64.org/showthread.php?tid=7686
i encountered the same problem in dietpi. seems my sandisk sd card was at fault. i bought a transcend and dietpi started without this problem. I hope that helps you narrow it down.
  Latest images from different distros failing to boot from SD card jmonty42 2 4,199 11-17-2020, 09:32 AM
Last Post: pagesix1536
  Manjaro hangs on boot DAMO238 1 3,236 07-08-2019, 08:14 AM
Last Post: DAMO238
  Adding coherent_pool to boot.cmd on Xenial Mate by Ayufan causes boot loop k_mp 0 1,928 06-11-2019, 01:36 PM
Last Post: k_mp
  Blank Screen on Boot MECZero 4 6,969 05-12-2019, 11:54 AM
  how do I boot to SD? (1080) tedder 7 8,197 11-16-2018, 03:15 AM
Last Post: Surehand53
  How to get text boot on KDE Neon maldus 5 6,816 11-13-2018, 04:29 AM
Last Post: maldus
  usb boot pinebook? BUBLOS 3 6,619 10-19-2017, 08:49 AM
Last Post: BUBLOS
  found fix for man tlaswell 1 2,528 08-25-2017, 09:56 AM
Last Post: MarkHaysHarris777
Information Minimal install wireless and usb ethernet pfeerick 0 2,092 06-28-2017, 09:26 PM
Last Post: pfeerick
  Stuck during the boot after soft reboot 0 1,008 Less than 1 minute ago
Last Post:
