How to Configure Screen Brightness in mate on pinebook via terinal?
I'm trying to bind brightness change to buttons via terminal in i3, but I can't find a command that will doing that:
pine64@pinebook:~$ sudo xrandr --listmonitors
Output is:
xrandr: Failed to get size of gamma for output default
Monitors: 1
 0: +*default 1366/361x768/203+0+0  default
So, when I trying to change it like:
pine64@pinebook:~$ sudo xrandr --output default --brightness 0.5
It isn't do anything.
pine64@pinebook:~$ echo 240 > /sys/class/backlight/lcd0/brightness
Have not do anything too Sad
I found this, but it is not working with sudo, only after sudo su
root@pinebook:/home/pine64# echo 50 > /sys/class/backlight/lcd0/brightness
Okay, now is the question how to make my own xbacklight with -dec 10 and -inc 10 to bind this for keyboard keys Smile
(08-31-2017, 12:28 PM)shirman Wrote: I found this, but it is not working with sudo, only after sudo su
... two scripts , one for key +  one for key -
Your script needs to read the value into a variable ,  add 10 to it ,  and then write the variable back out;  but, only if the +10 will not exceed 100.
Do the same for the minus key binding, only don't allow it to go below say 30 ( idk, experiment ).
also,  try:    sudo  -i
Shy
Ok, here are the scripts :
lcd_plus.sh
#!/bin/bash
LCDVALUE=`cat /sys/class/backlight/lcd0/brightness`
NEWVALUE=$(( $LCDVALUE + 10 ))
if [ $NEWVALUE -le 100 ]
then
   echo $NEWVALUE > /sys/class/backlight/lcd0/brightness
   echo $NEWVALUE
else
   echo $LCDVALUE
fi
lcd_minus.sh
#!/bin/bash
NEWVALUE=$(( $LCDVALUE - 10 ))
if [ $NEWVALUE -gt 30 ]
then
   echo $NEWVALUE
else
   echo $LCDVALUE
fi
try running them with  :
     sudo  -i
     ./lcd_plus.sh
     ./lcd_minus.sh
Now all that has to be done in i3 is to bind them to a keysym  using exec !
Works well.
Shy
Note:  of course,  you could combine them into a single script and pass a parm (up) or (down)
try it !
Ok,  expanding on a theme, I have combined the scripts here into one script that takes two parameters;  the first is the direction ( U for up;  D for down ) and the second is the scalar value.
lcd_bright.sh
#!/bin/bash
MODE=`echo $1 |tr '[a-z]' '[A-Z]'`
if [ "$MODE" = "U" ]
then
   NEWVALUE=$(( $LCDVALUE + $2 ))
   then
       echo $NEWVALUE
   else
       echo $LCDVALUE
   fi
else
   NEWVALUE=$(( $LCDVALUE - $2 ))
   then
       echo $NEWVALUE
   else
       echo $LCDVALUE
   fi
fi
Run the script with :
       sudo  -i
       ./lcd_bright.sh  U  10
or
       ./lcd_bright.sh  D  10
Notes:
       The U and D  can be upper or lower case ( the script upper cases it for you ).
       The script might be changed to set a maximum or minimum based on parameter--  try it !
Shy
Thank you a lot Smile I did bindings and it is working really good!
Even without "sudo -i" after "sudo chown pine64: brightness" command Smile
Excellent dude!   Big Grin
I got my bindings to work too, in i3,  with bindsym(s) in  ~/.config/i3/config
... but first I created a group called gpio_pins,  to give permissions to write to the file brightness, and added my pine64 user to the group!
 Also, I added a rule to my sudoers configuration ( use visudo ) similar to this:
# my extra rules
Cmnd_Alias LCDBRIGHT=/usr/local/sbin/lcd_bright.sh
ALL ALL=NOPASSWD: LCDBRIGHT
Then in ~/.config/i3/config  I added a bindsym near the bottom:
bindsym $mod+Shift+u  exec  sudo lcd_bright.sh u 10
bindsym $mod+Shift+d  exec  sudo lcd_bright.sh d 10
Then,  restart i3  with mod+Shift+r
...  now  mod+Shift+u  turns up the brightness,  and  mod+Shift+d  turns down the brightness.
nice
Shy
Thank you for the great advice @MarkHaysHarris777!
To get this work on my Pinebook (1080p - Arch image with i3) I had to change the file from  /sys/class/backlight/lcd0/brightness to /sys/class/backlight/backlight/brightness, the top value from 100 to 10  and the stepping to single digits. I'm not sure if this is due to the hardware or the os or both.
To get the max possible value: `cat /sys/class/backlight/backlight/max_brightness`
The script to raise the brightness then looks like this:
#!/bin/bash
LCDVALUE=`cat /sys/class/backlight/backlight/brightness`
NEWVALUE=$(( $LCDVALUE + 1 ))
if [ $NEWVALUE -le 10 ]
then
  echo $NEWVALUE > /sys/class/backlight/backlight/brightness
  echo $NEWVALUE
else
  echo $LCDVALUE
fi
and the one to decrease it (careful - this can completely dim the screen when the value gets to 0):
#!/bin/bash
NEWVALUE=$(( $LCDVALUE - 1 ))
if [ $NEWVALUE -ge 0 ]
then
  echo $NEWVALUE
else
  echo $LCDVALUE
fi
More info: https://wiki.archlinux.org/index.php/backlight
  DietPi OS for Pinebook MichaIng 3 5,364 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 60,841 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 886 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 681 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,565 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,213 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,843 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,228 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,802 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,792 12-25-2020, 04:40 PM
Last Post: ford442
