case for RockPro64 + PCI-E M.2 NVMe Card?
(08-09-2019, 03:53 PM)vorondil Wrote: Hello, I'm also looking for an option.
Does anybody knows if it would it fit in the "NAS" case?
Do you think they would be any benefit/disadvantage in the added power supply?
An alternative solution may be the use of  PINEBOOK Pro's M.2/NGFF NVMe SSD Interface Adapter.
This is at least what @pfeerick  is trying to do
see:
https://forum.pine64.org/showthread.php?tid=7757
(07-26-2019, 09:48 PM)pfeerick Wrote:
(07-26-2019, 04:32 AM)abdel Wrote: I was talking about rockpro64 board ...  there is no way to connect it because no  40/50 pin FFC  connector on rockpro.
lol... yeah... it's nothing more than a M-keyed M.2 -> FFC ribbon connector, just like how the rockpro64 adapter is a M-keyed M.2 one, but to PCIe x4 in that instance. I've actually ordered one of these riser card extenders to see if I can mount the NVMe adapter card differently... as then I can think about putting the rockpro64 in a case...  Smile
Derp: Would be a good idea to actually past the link I intended to paste in... :facepalm: ... https://www.aliexpress.com/item/33040463627.html
RE: case for RockPro64 + PCI-E M.2 NVMe Card? - by abdel - 08-10-2019, 01:07 AM
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,064 04-01-2024, 10:24 PM
Last Post: nano2
  AW-CM256SM wifi card mtek 4 2,365 10-30-2023, 12:00 PM
Last Post: diederik
  Powering on the Rockpro64 JPT223 1 915 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  Which SATA card should I use my NAS server RAID5 Louysa 3 914 09-24-2023, 04:40 AM
Last Post: JPT223
  ADATA XPG SX8200 Pro 2TB NVMe SSD Perf Atch 0 684 04-01-2023, 02:51 PM
Last Post: Atch
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,921 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 862 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,648 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 6,722 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 1,160 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
