RockPro64 not booting up
I have a number of RockPro64 4Gb boards, and some days ago, after powering down the cluster one of the devices is no longer booting. I have tested it with another MicroSD and is not working either. Both MicoSD cards are booting properly on another RockPro64 device.
I have tried powering down, pressing the power button for many seconds (many times), pressing reset and pressing power button after, pressing both power and reset buttons, but no solution at all.
I see some link in the ethernet switch, that is blinking for some seconds and then turning off. Some other times it just keeps blinking for a long period of time until I press reset or power buttons, then it stops blinking definitely.
I wonder if you could give me an advice on how to solve this issue.
  ROCKPro64 Battery Power Supply hoarfrosty 12 1,894 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 878 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,616 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 834 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,595 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 6,552 11-08-2022, 03:40 AM
Last Post: ajtravis
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,324 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 2,132 05-27-2022, 06:51 PM
Last Post: justwantin
  charging 3 rockpro64 from single source rpt312 1 1,718 05-16-2022, 02:34 AM
Last Post: dukla2000
  help or suggestions removing RockPro64 Playbox please? jahway603 2 2,361 03-22-2022, 12:17 PM
Last Post: jahway603
