ADATA XPG SX8200 Pro 2TB NVMe SSD Perf
This post is mainly to share my tests result, but I have two questions:
- Did someone managed to boot from this SSD? Boot from Intel 660p 2 TB works fine but not this one?
I noticed that my tests on the Intel 660p 2 TB are slower than before any idea why?
I am using Armbian with linux kerne5.15.93-rockchip64 #23.02.2, we might get better results on linux kernel v4?
Note: The RP64 has a PCIe NVMe v2.0 x4 (not a v3.0) the speed is limited and not representative of the SSD real performance.
WRITE
sync; dd if=/dev/zero of=tempfile bs=512 count=1024 oflag=dsync; sync; rm tempfile
524288 bytes (524 kB, 512 KiB) copied, 0.720266 s, 728 kB/s
sync; dd if=/dev/zero of=tempfile bs=1M count=1024; sync; rm tempfile
1073741824 bytes (1.1 GB, 1.0 GiB) copied, 3.60083 s, 298 MB/s
sync; dd if=/dev/zero of=tempfile bs=1G count=4 oflag=dsync; sync
4294967296 bytes (4.3 GB, 4.0 GiB) copied, 15.6034 s, 275 MB/s
READ
dd if=tempfile of=/dev/null bs=512 count=2048
1048576 bytes (1.0 MB, 1.0 MiB) copied, 0.0285999 s, 36.7 MB/s
dd if=tempfile of=/dev/null bs=1M count=1024
1073741824 bytes (1.1 GB, 1.0 GiB) copied, 2.00752 s, 535 MB/s
dd if=tempfile of=/dev/null bs=2M count=2048
4294967296 bytes (4.3 GB, 4.0 GiB) copied, 7.23786 s, 593 MB/s
[b]sync; sudo sysctl vm.drop_caches=3
hdparm -tT --direct /dev/nvme0n1[/b]
Timing O_DIRECT cached reads:   1096 MB in  2.00 seconds = 548.08 MB/sec
Timing O_DIRECT disk reads: 1714 MB in  3.00 seconds = 570.76 MB/sec
hdparm -Tt /dev/nvme0n1
Timing cached reads:   2472 MB in  2.00 seconds = 1235.97 MB/sec
Timing buffered disk reads: 1484 MB in  3.00 seconds = 494.27 MB/sec
The distribution / kernel seems to be the reason for the change of speed:
https://forum.pine64.org/showthread.php?...4#pid43884
The kernel version seems to be a reason for the change of speed:
  Full Size Bracket for the NVME PCI-E Card publiclewdness 0 1,386 12-31-2021, 12:53 AM
Last Post: publiclewdness
  PCI-E X4 to M.2/NGFF NVMe SSD - support? AndyOfLinux 22 28,424 12-13-2021, 11:04 AM
Last Post: Cerberus
  zfs on rockpro64 - any dual nvme PCI adapter for software raid ? romadr 0 1,937 04-22-2021, 02:59 PM
Last Post: romadr
  case for RockPro64 + PCI-E M.2 NVMe Card? AndyOfLinux 9 12,738 01-05-2021, 05:05 PM
Last Post: kuleszdl
  12V 3A power supply and NVMe - PCIe kaylios 3 4,981 08-25-2019, 03:31 AM
Last Post: kaylios
  using PINEBOOK Pro M.2/NGFF NVMe SSD Interface Adapter abdel 4 7,907 07-26-2019, 09:48 PM
Last Post: pfeerick
  Discovered issues with PCIe NVMe & GPU Load in desktop 4.4.174 causing board lockup axelf 0 1,978 04-08-2019, 03:51 PM
Last Post: axelf
  Fitting nvme card in open enclosure vbb 0 1,974 12-29-2018, 02:54 PM
Last Post: vbb
  Any benchmarks for non-pine64 pci to NVMe adapters? crhawle 2 5,268 09-10-2018, 12:47 PM
Last Post: dukla2000
