ANNOUNCING *BETA* RELEASE OF RECALBOX FOR THE ROCK64
#21
(08-10-2018, 08:04 AM)Danielsan Wrote:
(08-09-2018, 05:26 PM)Mrfixit2001 Wrote: RA is retroarch. The current bug affects how emulationstation learns triggers and passes them to retroarch as button mappings. We don't think it's limited to just the rock64, just FYI, and it is only for some controllers (who have their triggers pressure sensitive).
A possible workaround is to not remap the controller in emulationstation, instead after you start the rom enter the retroarch menu and change the input mappings from that menu instead.
Oh my, what a dumb... Big Grin
Now I understood and I'll try it,  however my wireless gamepad worked fine with the Alpha release...
Haha Not dumb at all, no such thing as a bad question because someone else would have asked the same thing.
Much had changed since Alpha, including newer versions of recalbox, retroarch, emulators, and back-end Linux libraries. Technically this "bug" is caused because of an "enhancement" somewhere that allows the triggers to work like axises and be pressure sensitive instead of just another button on/off. Unfortunately retroarch doesn't like that very much. The recalbox team is aware of the issue and has been thinking up fixes. Once they be have something I'll include it in our build.
RE: ANNOUNCING *BETA* RELEASE OF RECALBOX FOR THE ROCK64 - by Mrfixit2001 - 08-10-2018, 08:31 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 199 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,438 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 379 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 689 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 671 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,798 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 194,457 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 633 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 686 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 34,759 12-07-2022, 08:22 PM
Last Post: luminosity7
