ANNOUNCING *BETA* RELEASE OF RECALBOX FOR THE ROCK64
(08-05-2018, 03:23 PM)pascal06n Wrote: I've a probem with the beta.
With Recalbox I don't see anything on the screen. I used a HDMI > DVI cable. The monitor is not detecting any signal.
(I confirm the HDMI > DVI works fine : I used other linux version).
I can access recalbox web interface, ssh is working fine as well.
I've tried with several settings in recalbox-conf :
global.videomode=CEA 1 HDMI
or
global.videomode=DMT 35 HDMI
I've also created a config.txt in /boot
With these settings :
hdmi_force_hotplug=1
config_hdmi_boost=4
hdmi_group=1
hdmi_drive=1
hdmi_mode=4
not better...
But I've tried several setting on the web interface and I've noticed something really weird : if I start by default on Kodi I see Kodi (display is working fine). But if I let recalbox starting (or if I go back from odi to recalbox)... it doesn't work.  I've tried with other linux img such as debian, lakka, I don't have the same problem...
Any idea ?
Try removing:
video=HDMI-A-1:1920x1080@60
in /BOOT/extlinux/extlinux.conf
See if that will work. Whats the native res of the monitor ?
RE: ANNOUNCING *BETA* RELEASE OF RECALBOX FOR THE ROCK64 - by Luke - 08-05-2018, 03:34 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 195 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,431 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 377 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 686 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 665 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,787 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 194,332 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 630 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 684 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 34,700 12-07-2022, 08:22 PM
Last Post: luminosity7
