0.7.8 Linux release from ayufan for Rock64
#28
Hi Guys, my RTC PCF8523(https://www.adafruit.com/product/3386) is not working on the Rock64.
It is working on the RPI3B:
root@rpi3b01:~# uname -a
Linux rpi3b01 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l GNU/Linux
root@rpi3b01:~# modinfo rtc-pcf8523
filename:       /lib/modules/4.14.79-v7+/kernel/drivers/rtc/rtc-pcf8523.ko
license:        GPL v2
description:    NXP PCF8523 RTC driver
author:         Thierry Reding <thierry.reding@avionic-design.de>
srcversion:     88403DCB7B29428A4B359BE
alias:          i2c:pcf8523
alias:          of:N*T*Cnxp,pcf8523C*
depends:
intree:         Y
vermagic:       4.14.79-v7+ SMP mod_unload modversions ARMv7 p2v8
root@rpi3b01:~# i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
It works and being used.
root@rock64:~# uname -a
Linux rock64 4.4.154-1128-rockchip-ayufan-g61b4b1151f9a #1 SMP Tue Dec 25 14:31:31 UTC 2018 aarch64 GNU/Linux
root@rock64:~# modinfo rtc-pcf8523
filename:       /lib/modules/4.4.154-1128-rockchip-ayufan-g61b4b1151f9a/kernel/drivers/rtc/rtc-pcf8523.ko
license:        GPL v2
alias:          i2c:pcf8523
alias:          of:N*T*Cnxp,pcf8523*
depends:
vermagic:       4.4.154-1128-rockchip-ayufan-g61b4b1151f9a SMP mod_unload aarch64
Enabling i2c0:
root@rock64:~# enable_dtoverlay i2c0 i2c@ff150000 okay
Applying...
/dts-v1/;
        fragment@0 {
                target-path = "/i2c@ff150000";
                __overlay__ {
                        status="okay";
Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
Applied!
Right now it the RTC module is not plugged in:
root@rock64:~# i2cdetect -y 0
00:          03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f
10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
30: -- -- -- -- -- -- -- -- 38 39 3a 3b 3c 3d 3e 3f
40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f
70: 70 71 72 73 74 75 76 77
If I add the RTC PCF8523. It does not pop at 0x68 as on my RPI3B.
What else should be done in order to get the RTC module working?
Thnx for your help!
RE: 0.7.8 Linux release from ayufan for Rock64 - by Ice - 01-27-2019, 03:19 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 193 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,429 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 371 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 679 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 663 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,758 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 193,781 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 629 07-09-2023, 03:28 AM
Last Post: nemnob
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,810 06-02-2023, 07:52 AM
Last Post: diederik
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 683 05-27-2023, 06:11 AM
Last Post: Transportsicherung
