[solved] Unable to start X
Before upgrade:
ls -la /etc/X11/xorg.conf.d/
-rw-r--r-- 1 root root  177 Oct 12  2017 20-modesetting.conf
After upgrade:
-rw-r--r-- 1 root root  564 May 28 03:33 20-armsoc.conf
-rw-r--r-- 1 root root  177 May 28 03:33 20-modesetting.conf.bak
Restart. after doing the following
# cd /etc/X11/xorg.conf.d/
# mv 20-armsoc.conf 20-armsoc.conf.bak
There is another way to build from source code.
However, there is no big advantage in doing it
ayufan-rock64/xf86-video-armsoc
https://github.com/ayufan-rock64/xf86-vi...ial.tar.gz
[solved] Unable to start X - by Osiander - 07-09-2018, 06:56 AM
RE: Unable to start X - by zet_lab - 07-09-2018, 11:03 AM
RE: Unable to start X - by t4_4t - 07-09-2018, 05:37 PM
RE: Unable to start X - by pfeerick - 07-09-2018, 06:06 PM
RE: Unable to start X - by t4_4t - 07-09-2018, 09:25 PM
RE: Unable to start X - by Osiander - 07-10-2018, 04:09 AM
RE: Unable to start X - by Falkor - 07-11-2018, 06:52 AM
RE: [solved] Unable to start X - by Osiander - 07-12-2018, 10:46 AM
RE: [solved] Unable to start X - by jovval - 10-03-2018, 03:54 AM
  Display limited to 800x600 [SOLVED] Averell 16 18,866 06-05-2020, 11:07 PM
Last Post: ab1jx
  Unable to boot armbian fchazal 2 3,894 05-19-2020, 06:43 PM
Last Post: Rocklobster
Question [SOLVED] Alpine Linux won't boot rock7 1 5,817 10-22-2019, 04:30 PM
Last Post: rock7
  gstreamer unable to process dvbsrc from ATSC tuner dongle grkblood13 1 2,990 08-31-2019, 09:01 PM
Last Post: grkblood13
  Freeze/reboot/errors when compiling - unable to make - reproducible and not isolated jovval 2 3,926 10-02-2018, 08:10 AM
Last Post: jovval
  If you've messed up your eMMC Card - Solved gregb49 11 16,561 07-11-2018, 02:08 PM
Last Post: gregb49
  rock64/ubuntu start-up pas059 36 41,475 06-28-2018, 08:43 AM
Last Post: pas059
  Any reason why ntp time is 6 minutes slow (Solved) Rocklobster 1 2,564 05-29-2018, 05:27 AM
  [Solved] Open VPN +Wi-Fi hotspot - Debian S3phi40T 1 2,935 05-01-2018, 05:51 AM
Last Post: S3phi40T
  [PROBLEM SOLVED] Distcc Help cooker 2 4,034 05-01-2018, 05:35 AM
Last Post: cooker
