[SOLVED] Alpine Linux won't boot
Question
It should work, according to this thread:
https://forum.pine64.org/showthread.php?tid=5881
I have done the following instructions:
https://wiki.alpinelinux.org/wiki/DIY_Fu...r_ARM_SOCs
https://github.com/ayufan-rock64/linux-b...ash-spi.md
With the help of the following websites:
https://forum.pine64.org/showthread.php?tid=4928
https://a-delacruz.github.io/alpine/alpine-linux.html
U-Boot is now on the SPI memory of the Rock64
Then I tried to boot Alpine Linux from a USB stick:
Quote:Result 1:
Quote:With USB stick and this extlinux.conf:
LABEL Linux 5.3.0
LINUX /boot/vmlinuz-5.3.0
INITRD /boot/initramfs-neu
FDT /boot/dtbs/rk3328-rock64.dtb
APPEND BOOT_IMAGE=/boot/vmlinuz-5.3.0 modules=loop,squashfs,sd-mod,usb-storage modloop=/boot/modloop-neu console=${console}
Serial Console output:
U-Boot SPL 2017.09-rockchip-ayufan-1063-g29843fbd42 (Jul 08 2019 - 11:55:08)
board_init_sdmmc_pwr_en
setup_ddr_param 1
booted from SPI flash
Trying to boot from SPI
NOTICE: BL31: v1.3(debug):9d3f591
NOTICE: BL31: Built : 14:39:02, Jan 17 2018
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
INFO: BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE iniK
ERROR: Error initializing runtime service opteed_fast
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-rockchip-ayufan-1063-g29843fbd42 (Jul 08 2019 - 11:55:26 +0000)
Model: Pine64 Rock64
DRAM: 4 GiB
MMC: rksdmmc@ff520000: 0, rksdmmc@ff500000: 1
SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
*** Warning - bad CRC, using default environment
In: serial@ff130000
Out: serial@ff130000
Err: serial@ff130000
misc_init_r
cpuid=55524b50303930313500000000023119
serial=7223c9dfddbf101
Net: eth0: ethernet@ff540000
Hit any key to stop autoboot: 0
Card did not respond to voltage select!
mmc_init: -95, time 10
mmc_init: -95, time 9
starting USB...
USB0: USB EHCI 1.00
USB1: USB OHCI 1.0
USB2: Core Release: 3.10a
USB3: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 2 USB Device(s) found
scanning bus 3 for devices... 1 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Device 0: Vendor: General Rev: 5.00 Prod: UDisk
Type: Removable Hard Disk
Capacity: 3840.0 MB = 3.7 GB (7864320 x 512)
... is now current device
Scanning usb 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
reading /boot/extlinux/extlinux.conf
233 bytes read in 26 ms (7.8 KiB/s)
1: Linux 5.3.0
Retrieving file: /boot/initramfs-neu
reading /boot/initramfs-neu
7170333 bytes read in 457 ms (15 MiB/s)
Retrieving file: /boot/vmlinuz-5.3.0
reading /boot/vmlinuz-5.3.0
31175168 bytes read in 1876 ms (15.8 MiB/s)
append: BOOT_IMAGE=/boot/vmlinuz-5.3.0 modules=loop,squashfs,sd-mod,usb-storage=
Retrieving file: /boot/dtbs/rk3328-rock64.dtb
reading /boot/dtbs/rk3328-rock64.dtb
36633 bytes read in 38 ms (941.4 KiB/s)
## Loading init Ramdisk from Legacy Image at 04000000 ...
Image Name: initramfs-sunxi
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 7170269 Bytes = 6.8 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Loading Ramdisk to fc82b000, end fcf018dd ... OK
Loading Device Tree to 00000000fc81f000, end 00000000fc82af18 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.3.0-rc4-1117-ayufan-g01ec52ee6e2e (root@runner-f9
[ 0.000000] Machine model: Pine64 Rock64
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000ff130000 (options '')
[ 0.000000] printk: bootconsole [uart8250] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 16 MiB at 0x00000000fe000000
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000ff130000 (options '150000)
MORE IS NOT DISPLAYED, MORE DOES NOT WORK
Quote:Result 2:
Quote:With USB stick and this boot.scr:
setenv bootargs earlyprintk /boot/vmlinuz-5.3.0 modules=loop,squashfs,sd-mod,usb-storage modloop=/boot/modloop-neu console=${console}
load mmc 0:1 0x43000000 boot/dtbs/rk3328-rock64.dtb
load mmc 0:1 0x41000000 boot/vmlinuz-5.3.0
load mmc 0:1 0x45000000 boot/initramfs-neu
booti 0x41000000 0x45000000 0x43000000
setup_ddr_param  1
INFO:    SPSR = 0x3c9
DRAM:  4 GiB
In:    serial@ff130000
misc_init_r
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB XHCI 1.10
Scanning usb 0:1...
Found U-Boot script /boot/boot.scr
reading /boot/boot.scr
383 bytes read in 21 ms (17.6 KiB/s)
## Executing script at 00500000
"Synchronous Abort" handler, esr 0x96000210
ELR:     fef6af14
LR:      fef18fb8
x0 : 0000000000000000 x1 : 0000000000000001
x2 : 0000000000000010 x3 : 0000000000000000
x4 : 000000000000000a x5 : 00000000fef8585b
x6 : 0000000000000001 x7 : 0000000000000008
x8 : 0000000000000044 x9 : 0000000000000008
x10: 00000000fcf02d3e x11: 0000000000000006
x12: 000000000001869f x13: 0000000000000004
x14: 0000000000000004 x15: 00000000ffffffff
x16: 00000000cb5bab3b x17: 00000000800580a1
x18: 00000000fcf0ce08 x19: 0000000000000000
x20: 00000000fcf4f070 x21: 00000000fcf4f000
x22: 00000000fefb2000 x23: 00000000fcf4f020
x24: 0000000000000000 x25: 0000000000000000
x26: 0000000000000000 x27: 0000000000000000
x28: 00000000fcf4eaf0 x29: 00000000fcf032a0
Resetting CPU …
setup_ddr_param  1
INFO:    SPSR = 0x3c9
DRAM:  4 GiB
In:    serial@ff130000
misc_init_r
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB XHCI 1.10
scanning bus 2 for devices... Device NOT ready
   Request Sense returned 02 3A 00
Device NOT ready
       scanning usb for storage devices... 2 Storage Device(s) found
Device 0: Vendor: Generic- Rev: 1.00 Prod: USB3.0 CRW   -SD
            Capacity: not available
My usb stick (newos) looks like this:
/media/ubuntu/newos
/media/ubuntu/newos/apks
/media/ubuntu/newos/apks/.boot_repository
/media/ubuntu/newos/apks/aarch64
/media/ubuntu/newos/apks/aarch64/kbd-bkeymaps-2.0.4-r3.apk
/media/ubuntu/newos/apks/aarch64/wireless-tools-30_pre9-r1.apk
/media/ubuntu/newos/apks/aarch64/openssl-1.1.1c-r0.apk
/media/ubuntu/newos/apks/aarch64/alpine-mirrors-3.5.10-r0.apk
/media/ubuntu/newos/apks/aarch64/busybox-1.30.1-r2.apk
/media/ubuntu/newos/apks/aarch64/ppp-pppoe-2.4.7-r6.apk
/media/ubuntu/newos/apks/aarch64/alpine-base-3.10.1-r0.apk
/media/ubuntu/newos/apks/aarch64/haveged-openrc-1.9.4-r4.apk
/media/ubuntu/newos/apks/aarch64/ncurses-libs-6.1_p20190518-r0.apk
/media/ubuntu/newos/apks/aarch64/openssh-server-8.0_p1-r0.apk
/media/ubuntu/newos/apks/aarch64/musl-1.1.22-r2.apk
/media/ubuntu/newos/apks/aarch64/ppp-daemon-2.4.7-r6.apk
/media/ubuntu/newos/apks/aarch64/ppp-atm-2.4.7-r6.apk
/media/ubuntu/newos/apks/aarch64/libnl3-3.4.0-r0.apk
/media/ubuntu/newos/apks/aarch64/vlan-2.2-r0.apk
/media/ubuntu/newos/apks/aarch64/libcom_err-1.45.2-r0.apk
/media/ubuntu/newos/apks/aarch64/network-extras-1.2-r0.apk
/media/ubuntu/newos/apks/aarch64/APKINDEX.tar.gz
/media/ubuntu/newos/apks/aarch64/openssh-8.0_p1-r0.apk
/media/ubuntu/newos/apks/aarch64/libssl1.1-1.1.1c-r0.apk
/media/ubuntu/newos/apks/aarch64/ppp-passwordfd-2.4.7-r6.apk
/media/ubuntu/newos/apks/aarch64/wpa_supplicant-openrc-2.8-r1.apk
/media/ubuntu/newos/apks/aarch64/pcsc-lite-libs-1.8.25-r1.apk
/media/ubuntu/newos/apks/aarch64/scanelf-1.2.3-r0.apk
/media/ubuntu/newos/apks/aarch64/openssh-server-common-8.0_p1-r0.apk
/media/ubuntu/newos/apks/aarch64/openssh-client-8.0_p1-r0.apk
/media/ubuntu/newos/apks/aarch64/ppp-winbind-2.4.7-r6.apk
/media/ubuntu/newos/apks/aarch64/zlib-1.2.11-r1.apk
/media/ubuntu/newos/apks/aarch64/openrc-0.41.2-r1.apk
/media/ubuntu/newos/apks/aarch64/e2fsprogs-1.45.2-r0.apk
/media/ubuntu/newos/apks/aarch64/alpine-baselayout-3.1.2-r0.apk
/media/ubuntu/newos/apks/aarch64/libcap-2.27-r0.apk
/media/ubuntu/newos/apks/aarch64/ssl_client-1.30.1-r2.apk
/media/ubuntu/newos/apks/aarch64/chrony-3.5-r0.apk
/media/ubuntu/newos/apks/aarch64/ppp-passprompt-2.4.7-r6.apk
/media/ubuntu/newos/apks/aarch64/libedit-20190324.3.1-r0.apk
/media/ubuntu/newos/apks/aarch64/bonding-2.6-r4.apk
/media/ubuntu/newos/apks/aarch64/alpine-keys-2.1-r2.apk
/media/ubuntu/newos/apks/aarch64/libuuid-2.33.2-r0.apk
/media/ubuntu/newos/apks/aarch64/libtls-standalone-2.9.1-r0.apk
/media/ubuntu/newos/apks/aarch64/dbus-libs-1.12.16-r0.apk
/media/ubuntu/newos/apks/aarch64/ppp-l2tp-2.4.7-r6.apk
/media/ubuntu/newos/apks/aarch64/bridge-1.5-r4.apk
/media/ubuntu/newos/apks/aarch64/libcrypto1.1-1.1.1c-r0.apk
/media/ubuntu/newos/apks/aarch64/ncurses-terminfo-base-6.1_p20190518-r0.apk
/media/ubuntu/newos/apks/aarch64/ca-certificates-cacert-20190108-r0.apk
/media/ubuntu/newos/apks/aarch64/alpine-conf-3.8.3-r0.apk
/media/ubuntu/newos/apks/aarch64/ppp-chat-2.4.7-r6.apk
/media/ubuntu/newos/apks/aarch64/wpa_supplicant-2.8-r1.apk
/media/ubuntu/newos/apks/aarch64/busybox-suid-1.30.1-r2.apk
/media/ubuntu/newos/apks/aarch64/tzdata-2019a-r0.apk
/media/ubuntu/newos/apks/aarch64/musl-utils-1.1.22-r2.apk
/media/ubuntu/newos/apks/aarch64/usb-modeswitch-2.5.2-r0.apk
/media/ubuntu/newos/apks/aarch64/ncurses-terminfo-6.1_p20190518-r0.apk
/media/ubuntu/newos/apks/aarch64/libusb-1.0.22-r0.apk
/media/ubuntu/newos/apks/aarch64/openssh-keygen-8.0_p1-r0.apk
/media/ubuntu/newos/apks/aarch64/e2fsprogs-libs-1.45.2-r0.apk
/media/ubuntu/newos/apks/aarch64/apk-tools-2.10.4-r2.apk
/media/ubuntu/newos/apks/aarch64/ppp-radius-2.4.7-r6.apk
/media/ubuntu/newos/apks/aarch64/libc-utils-0.7.1-r0.apk
/media/ubuntu/newos/apks/aarch64/chrony-openrc-3.5-r0.apk
/media/ubuntu/newos/apks/aarch64/busybox-initscripts-3.1-r7.apk
/media/ubuntu/newos/apks/aarch64/haveged-1.9.4-r4.apk
/media/ubuntu/newos/apks/aarch64/ppp-minconn-2.4.7-r6.apk
/media/ubuntu/newos/apks/aarch64/libblkid-2.33.2-r0.apk
/media/ubuntu/newos/apks/aarch64/openssh-sftp-server-8.0_p1-r0.apk
/media/ubuntu/newos/boot
/media/ubuntu/newos/boot/vmlinuz-5.3.0
/media/ubuntu/newos/boot/config-5.3.0
/media/ubuntu/newos/boot/System.map-5.3.0
/media/ubuntu/newos/boot/initramfs-neu
/media/ubuntu/newos/boot/modloop-neu
/media/ubuntu/newos/boot/extlinux
/media/ubuntu/newos/boot/extlinux/extlinux.conf
/media/ubuntu/newos/boot/dtbs
/media/ubuntu/newos/boot/dtbs/rk3328-rock64.dtb
/media/ubuntu/newos/boot/boot.scr
/media/ubuntu/newos/alpine.apkovl.tar.gz
Thanks in advance for your help!
Information
Here is the solution:
https://forum.pine64.org/showthread.php?tid=8174
Archive.is: http://archive.is/w3uQN
Waybackmachine: https://web.archive.org/web/201910222216...881&page=2
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 139 03-24-2024, 01:07 PM
  Rock64 won't boot dstallmo 0 331 12-27-2023, 10:34 AM
Last Post: dstallmo
  arch rock64 does not boot nemnob 0 586 07-09-2023, 03:28 AM
Last Post: nemnob
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,734 06-02-2023, 07:52 AM
Last Post: diederik
  Disabling last mount time check on boot acwest 0 620 03-03-2023, 09:24 PM
Last Post: acwest
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 7,762 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,043 06-27-2022, 06:52 PM
  Linux 5.15 Kernel - openSuse mark1250 0 1,285 12-02-2021, 04:36 PM
Last Post: mark1250
  Alpine Linux isndw 12 17,784 08-12-2021, 05:41 PM
Last Post: pix
Lightbulb RK3399 Linux rtl8822cu module bluetooth not working shivarj89 0 1,355 07-29-2021, 07:19 AM
Last Post: shivarj89
