rock64/ubuntu start-up
#30
(06-27-2018, 04:07 AM)pas059 Wrote: Hi,
my power supply is this one. But it's not a ramdom crashe/freeze/reboot it's only during the first minutes after power up, after this time this works (no more auto reboot or crash).\
That power supply should do the job just fine... it could be a lemon though...
Quote:For my network issues, i had installed samba (and winbind + smbclient + cifs-utils) which was not installed with this version of OS. I done systmctl... but the problems remain. The last lines of log.smbd are:
[2018/06/27 10:37:32.828493,  0] ../lib/util/become_daemon.c:124(daemon_ready)
STATUS=daemon 'smbd' finished starting up and ready to serve connections
& similar things for log.nmbd
but the message (after samba install) is ""Failed to retrieve share list from server: connection refused"
I've got a couple more things for you to try:
Open /etc/samba/smb.conf in nano (or whatever text editor) with sudo. There should be a line something like this in the file:
name resolve order = bcast host
There may be more words after the equals sign, but that's irrelevant. What does matter is that "bcast" is first in that list. If it's not, move it to the first spot. Save that, and restart smbd/nmbd (systemctl restart <...>).
If that still didn't fix it, find the IP address of your Windows computer and run
smbclient -L <IP address>
Give us all the output from that command.
rock64/ubuntu start-up - by pas059 - 06-13-2018, 09:02 AM
RE: rock64/ubuntu stat-up - by Luke - 06-13-2018, 09:14 AM
RE: rock64/ubuntu stat-up - by pas059 - 06-13-2018, 10:41 AM
RE: rock64/ubuntu stat-up - by Luke - 06-13-2018, 01:27 PM
RE: rock64/ubuntu stat-up - by pas059 - 06-14-2018, 09:12 AM
RE: rock64/ubuntu stat-up - by pfeerick - 06-14-2018, 07:11 PM
RE: rock64/ubuntu stat-up - by Luke - 06-14-2018, 10:42 AM
RE: rock64/ubuntu stat-up - by pas059 - 06-14-2018, 12:00 PM
RE: rock64/ubuntu stat-up - by fire219 - 06-14-2018, 01:20 PM
RE: rock64/ubuntu stat-up - by pas059 - 06-15-2018, 12:26 PM
RE: rock64/ubuntu stat-up - by fire219 - 06-15-2018, 12:56 PM
RE: rock64/ubuntu stat-up - by pfeerick - 06-16-2018, 04:41 AM
RE: rock64/ubuntu stat-up - by pas059 - 06-16-2018, 10:10 AM
RE: rock64/ubuntu stat-up - by pfeerick - 06-16-2018, 04:15 PM
RE: rock64/ubuntu stat-up - by evilbunny - 06-16-2018, 05:05 PM
RE: rock64/ubuntu stat-up - by pfeerick - 06-16-2018, 05:18 PM
RE: rock64/ubuntu stat-up - by zet_lab - 06-16-2018, 11:58 PM
RE: rock64/ubuntu start-up - by pfeerick - 06-17-2018, 01:25 AM
RE: rock64/ubuntu start-up - by zet_lab - 06-17-2018, 11:58 AM
RE: rock64/ubuntu start-up - by pas059 - 06-18-2018, 11:56 AM
RE: rock64/ubuntu start-up - by fire219 - 06-18-2018, 09:04 PM
RE: rock64/ubuntu start-up - by pas059 - 06-19-2018, 02:29 AM
RE: rock64/ubuntu start-up - by pas059 - 06-21-2018, 09:45 AM
RE: rock64/ubuntu start-up - by fire219 - 06-21-2018, 11:25 AM
RE: rock64/ubuntu start-up - by pas059 - 06-21-2018, 11:57 AM
RE: rock64/ubuntu start-up - by pfeerick - 06-21-2018, 05:59 PM
RE: rock64/ubuntu start-up - by pas059 - 06-26-2018, 02:33 AM
RE: rock64/ubuntu start-up - by fire219 - 06-26-2018, 09:48 AM
RE: rock64/ubuntu start-up - by pas059 - 06-27-2018, 04:07 AM
RE: rock64/ubuntu start-up - by fire219 - 06-27-2018, 09:13 AM
RE: rock64/ubuntu start-up - by MrPosull - 06-27-2018, 11:44 AM
RE: rock64/ubuntu start-up - by pas059 - 06-27-2018, 12:36 PM
RE: rock64/ubuntu start-up - by fire219 - 06-27-2018, 01:00 PM
RE: rock64/ubuntu start-up - by pas059 - 06-28-2018, 03:42 AM
RE: rock64/ubuntu start-up - by pfeerick - 06-28-2018, 04:00 AM
RE: rock64/ubuntu start-up - by pas059 - 06-28-2018, 07:28 AM
RE: rock64/ubuntu start-up - by pas059 - 06-28-2018, 08:43 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 213 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,464 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 392 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 707 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 695 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,913 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 195,525 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 645 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 695 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 35,192 12-07-2022, 08:22 PM
Last Post: luminosity7
