How do you like the case?
Love it
50.00%
18
Like it
30.56%
11
Its not for me
19.44%
7
36 vote(s)
RockPro64 Case 2x3.5" HDDs and 2x2.5 HDDs
#46
(09-01-2019, 11:22 AM)Tim Jones Wrote:
(09-01-2019, 10:24 AM)Farley56 Wrote: My biggest beef is not knowing exactly how to shutdown/restart the device. Can anyone direct me to the documentation listing the steps to shutdown  the device? Not just the NASCase but the Rock64Pro too.
Hi Mark,
Shutdown takes the system down to the OFF state by running init 0, which shuts down all running processes
Reboot does just that - reboots - but uses init 6 which does the same as init 0, but with a reboot at the end
PowerOff is one step further in that it runs init 6, but then sends the ACPI command to kill power
None of these should come close to corrupting the eMMC or µSD card.  If any of them do, then there's an issue with either a processes not obeying the SIGTERM and SIGKILL commands sent during the finale stages on init 0.
If you would like to see this first hand, login on a direct-connect terminal and issue the init commands are rot:
init 0
init 6
HTH,
Tim
Thanks Tim. Good suggestion/explanation. I'll take a look. I'd imagine if it's a process corrupting the OMV load I'll have to spend some time looking through logs. A couple more questions;
* Can I assume that the OMV shutdown and reboot selections from the browser interface also use the same "init" code?
* Does using the Rock64Pro "reset" or "power" buttons accomplish the same thing?
* I don't want to be logged into the OMV browser interface if I wish to use the power button on the NASCase (Rock64Pro)?
* Worst thing to do is pull the AC power from the NASCase which kills everything immediately and without running any init code?
Thanks again,
Mark
Better fan option for the NAS case - by Tim Jones - 06-26-2019, 03:33 PM
RE: RockPro64 Case 2x3.5" HDDs and 2x2.5 HDDs - by Farley56 - 09-01-2019, 08:52 PM
  Installing Wifi drive for the RockPro64 John45595 0 343 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 813 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 709 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,332 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 927 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,371 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,887 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,735 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,040 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,845 10-21-2022, 07:44 AM
Last Post: rapier1
