How do you like the case?
Love it
50.00%
18
Like it
30.56%
11
Its not for me
19.44%
7
36 vote(s)
RockPro64 Case 2x3.5" HDDs and 2x2.5 HDDs
#42
One of the issues with the NAS case is the space required by most 80mm fans (usually 15mm or 25mm thick).  This can cause issues with the cabling and installation when using 3.5" disk drives.
In searching, I've found a solution that is only 10mm thick, but still provides 19CFM at 26dBA noise level.  It's from Wathai in China and is available on Most Amazon sites.  Here's the US Amazon link:
80mm x 5mm case fan
 (EDIT - the image on that page says 5VDC, but this is for the 12VDC fan)
If you're not an Amazon fan, Warthai's description is "80mm x 10mm 12V 2Pin DC Cooler Radiator Exhaust Cooling Fan"
Full specs:
  • 1 Piece fan and mounting screws & nuts
  • Rated Voltage:12V 0.1A; Speed: 2500RPM; Air flow: 18.9CFM; Noise:26dBA
  • Connecter: XH2.54-2Pin; Cable Length: 25cm Or 9.85 inches
  • Bearing type: Sleeve Bearing ; Life: 35000 hours
  • Dimension: 80mm(L) x 80mm(W) x 10mm(H) / 3.15x3.15x0.4 in. per fan
Better fan option for the NAS case - by Tim Jones - 06-26-2019, 03:33 PM
  Installing Wifi drive for the RockPro64 John45595 0 321 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 770 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 689 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,275 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 900 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,334 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,836 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,674 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,024 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,809 10-21-2022, 07:44 AM
Last Post: rapier1
