Xen hypervisor on Rock64
I was able to get a bit further with loading with the EFI approach.
First I flashed u-boot onto SPI flash.
Then I loaded the xen.efi onto a micro sd card (as bootaa64.efi), stopped the uboot autoboot,
and attempted to manually boot using efi.  This yields the errors shown below -- Any suggestions?
Hit any key to stop autoboot:  0
=> set devtype mmc
=> set devnum 1
=> set distro_bootpart 6
=> run boot_efi_binary
reading efi/boot/bootaa64.efi
885072 bytes read in 128 ms (6.6 MiB/s)
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
## Starting EFI application at 02000000 ...
Card did not respond to voltage select!
mmc_init: -95, time 10
Scanning disk rksdmmc@ff520000.blk...
Scanning disk rksdmmc@ff500000.blk...
Found 2 disks
Xen 4.11-rc (c/s Tue May 1 09:03:13 2018 +0100 git:0306a1311d) EFI loader
Couldn't obtain the File System Protocol Interface: ErrCode: 0x8000000000000003
## Application terminated, r = 0
For reference, here's what's on the sd card:
=> ls mmc 1:6
19644424   image
           efi/
           extlinux/
 2920159   initrd.img
   56922   dtb
     134   xen.cfg
=> ls mmc 1:6 efi/boot
   885072   bootaa64.efi
The existing Image and dtb boot OK (using /extlinux/extlinux.conf )  but xen does not boot.
Xen hypervisor on Rock64 - by tumbleweed - 05-13-2018, 09:03 PM
RE: Xen hypervisor on Rock64 - by evilbunny - 05-13-2018, 11:40 PM
RE: Xen hypervisor on Rock64 - by tumbleweed - 05-15-2018, 09:41 AM
RE: Xen hypervisor on Rock64 - by sstabellini - 05-17-2018, 07:05 PM
RE: Xen hypervisor on Rock64 - by tumbleweed - 05-19-2018, 02:35 PM
RE: Xen hypervisor on Rock64 - by tumbleweed - 05-23-2018, 09:36 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 193 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,429 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 377 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 686 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 665 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,785 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 194,310 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 630 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 684 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 34,689 12-07-2022, 08:22 PM
Last Post: luminosity7
