Rock64 - Stuck when do the soft reboot
Hi
Any clues about rock64 stuck after applying soft reboot from shell?
reboot: Restarting system
INFO:    PSCI Power Domain Map:
INFO:      Domain Node : Level 2, parent_node -1, State ON (0x0)
INFO:      Domain Node : Level 1, parent_node 0, State ON (0x0)
INFO:      Domain Node : Level 0, parent_node 0, State ON (0x0)
INFO:      CPU Node : MPID 0x0, parent_node 1, State ON (0x0)
INFO:      CPU Node : MPID 0x1, parent_node 1, State ON (0x0)
INFO:      CPU Node : MPID 0x2, parent_node 1, State ON (0x0)
INFO:      CPU Node : MPID 0x3, parent_node 1, State ON (0x0)
Booted the system
Logged in as root
reboot
Stuck at the above log.
Strangely, if I booted as rock64 user, if I do the sudo reboot, there is no issue of stuck after the above mentioned log.
I am searching on google, I found the following link with the same issue, but they closed it as resolved.
https://github.com/Kwiboo/linux-rockchip/issues/14
Can you anybody faced the same issue? and are there any solutions to solve this issue?
   The rock64 (1G with using 0.5.15-136 version) got stuck after applying the soft reboot. This issue is observed only when we reboot with root credentials, not with rock64 credentials. Not sure why.
   The system stuck at the following log
   I searched online for older issues of the same, found the following, but this issue was already resolved.
Any advises about how to resolve this issue? Infact I observed this issue only on one unit.
Thanks,
Ramprasad
Moderator note: Merged and moved thread. Please refrain from posting the same question multiple times and in the wrong product forums.
Rock64 - Stuck when do the soft reboot - by ramprasad - 04-23-2018, 10:15 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 172 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,402 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 356 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 652 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 640 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,617 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 192,049 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 612 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 670 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 34,053 12-07-2022, 08:22 PM
Last Post: luminosity7
