rock64 is on Armbian's supported boards list
(03-18-2018, 12:40 AM)thewonderer Wrote: Any feedback on performance and stability.  Not getting great throughput via USB3 Portable HDD across my LAN (about 40Mbps), not matter NTFS or EXT4. Thanks
Not running Armbian currently but I was having the same problem some time ago. (also tried Armbian with same result)
I think it mostly depended on the kernel I was using, check here for details on my journey.
Now a few days ago I updated to the latest kernel from Ayufan and USB3 / Ethernet performance has been great.  Getting a solid 90MB/s download and 70MB/s upload to my Rock64.
Currently running:
kernel: Linux rock64 4.4.120-rockchip-ayufan-213 #1 SMP Sun Apr 29 20:27:33 UTC 2018 aar
on the bionic beaver ubuntu image from here[url=https://github.com/ayufan-rock64/linux-build][/url]
If you decide to check it out and still get sucky performance let me know and I will post my samba config, I took a few some tweaks from the OMV config which I think also helped.
Now the only thing I am missing is the ability to run kodi with HW acceleration from Ubuntu.. Rolleyes
RE: rock64 is on Armbian's supported boards list - by KernelPanic - 05-17-2018, 01:40 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 193 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,429 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 371 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 679 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 663 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,758 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 193,782 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 629 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 683 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 34,604 12-07-2022, 08:22 PM
Last Post: luminosity7
