Linux Images (ROCK64)
(06-05-2018, 10:14 AM)jzhang18 Wrote: Actually,  The local boot process never finished after upgraded to new Kernel.  ..
I have no idea on how to fix  "Warning: root device does not exist" during kernel update.  search on internet, there are tons of similar posts.  it seems a very common issue in Linux world.
Thanks. I'm a new user having just received my Rock64 4GB plus 64gb eMMC plus 32 gb micros SD card all direct from Pine. I installed Mate on the SD Card then using the jumper for 3 seconds (actually a fan for a RPi) transfered the system to the eMMC. All booted perfectly. Browsed the web, fine.
Carried out
sudo apt-get update
sudo apt-get upgrade
Rebooted. All fine. Got message about software update which I tried, but the updater failed.
Installed Synaptic - updated the sources, installed updates, and rebooted.
I get the initial text booting notifications including your  "Warning: root device does not exist"
then blank screen - nothing.
I've done this twice now, except once I used
sudo apt-get dist-upgrade instead of updating through synaptic
then on reboot, after the initial text, scrolling by rapidly, I just got a blank screen.
Are there any clearer instructions on how to install the files from github and which ones to choose, or I should I just try another debian image?
PinePhone Beta 2GB/16GB Postmarket OS v23.06.1 Phosh 0.30.0 (not in use)
PineTab2 Arch Danctnix 6.4.2
Linux Images (ROCK64) - by pineadmin - 08-04-2017, 04:06 AM
RE: Linux Images (ROCK64) 0.4.16-83 - by pfeerick - 08-08-2017, 05:59 PM
RE: Linux Images (ROCK64) 0.4.16-83 - by senderg - 08-10-2017, 03:10 AM
RE: Linux Images (ROCK64) 0.4.16-83 - by Luke - 08-10-2017, 03:15 AM
RE: Linux Images (ROCK64) 0.4.16-83 - by senderg - 08-10-2017, 03:16 AM
RE: Linux Images (ROCK64) - by pineadmin - 08-16-2017, 03:59 AM
RE: Linux Images (ROCK64) - by stuartiannaylor - 08-21-2017, 09:10 PM
RE: Linux Images (ROCK64) - by MarkHaysHarris777 - 08-21-2017, 09:20 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 08-21-2017, 10:35 PM
RE: Linux Images (ROCK64) - by MarkHaysHarris777 - 08-21-2017, 11:29 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 08-21-2017, 11:44 PM
RE: Linux Images (ROCK64) - by radek - 08-21-2017, 11:59 AM
RE: Linux Images (ROCK64) - by Luke - 08-21-2017, 02:54 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 08-21-2017, 02:59 PM
RE: Linux Images (ROCK64) - by radek - 08-22-2017, 07:21 AM
RE: Linux Images (ROCK64) - by Luke - 08-22-2017, 07:32 AM
RE: Linux Images (ROCK64) - by Farley56 - 09-06-2017, 03:57 PM
RE: Linux Images (ROCK64) - by tllim - 09-06-2017, 06:31 PM
RE: Linux Images (ROCK64) - by Farley56 - 09-06-2017, 06:51 PM
RE: Linux Images (ROCK64) - by elatllat - 09-12-2017, 12:55 PM
RE: Linux Images (ROCK64) - by ayufan - 09-12-2017, 01:18 PM
RE: Linux Images (ROCK64) - by pineadmin - 09-12-2017, 11:56 PM
RE: Linux Images (ROCK64) - by Farley56 - 09-19-2017, 07:13 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 09-27-2017, 02:23 PM
RE: Linux Images (ROCK64) - by Farley56 - 09-27-2017, 06:16 PM
RE: Linux Images (ROCK64) - by stuartiannaylor - 09-27-2017, 07:45 PM
RE: Linux Images (ROCK64) - by pineadmin - 10-02-2017, 03:32 AM
RE: Linux Images (ROCK64) - by stuartiannaylor - 10-02-2017, 07:00 AM
RE: Linux Images (ROCK64) - by chitenavi - 10-24-2017, 12:26 AM
RE: Linux Images (ROCK64) - by Luke - 10-24-2017, 02:39 AM
RE: Linux Images (ROCK64) - by pineadmin - 10-24-2017, 02:30 AM
RE: Linux Images (ROCK64) - by chitenavi - 10-24-2017, 03:28 AM
RE: Linux Images (ROCK64) - by Luke - 10-24-2017, 03:57 AM
RE: Linux Images (ROCK64) - by chitenavi - 10-24-2017, 04:17 AM
RE: Linux Images (ROCK64) - by gene83 - 11-22-2017, 11:00 AM
RE: Linux Images (ROCK64) - by Rar9 - 12-04-2017, 10:14 AM
RE: Linux Images (ROCK64) - by Luke - 12-04-2017, 10:19 AM
RE: Linux Images (ROCK64) - by Rar9 - 12-04-2017, 11:19 AM
RE: Linux Images (ROCK64) - by Luke - 12-04-2017, 11:30 AM
RE: Linux Images (ROCK64) - by pineadmin - 12-08-2017, 04:42 AM
RE: Linux Images (ROCK64) - by thewonderer - 12-19-2017, 01:11 AM
RE: Linux Images (ROCK64) - by dkryder - 12-19-2017, 07:42 PM
RE: Linux Images (ROCK64) - by pineadmin - 12-21-2017, 12:27 AM
RE: Linux Images (ROCK64) - by Rar9 - 12-21-2017, 05:37 AM
RE: Linux Images (ROCK64) - by pineadmin - 12-22-2017, 04:24 AM
RE: Linux Images (ROCK64) - by Rar9 - 12-22-2017, 05:40 AM
RE: Linux Images (ROCK64) - by dkryder - 12-22-2017, 11:00 AM
Linux Images (ROCK64) - by Rar9 - 12-22-2017, 11:07 AM
RE: Linux Images (ROCK64) - by dkryder - 12-22-2017, 03:36 PM
RE: Linux Images (ROCK64) - by pineadmin - 01-04-2018, 04:58 AM
RE: Linux Images (ROCK64) - by gene83 - 01-13-2018, 05:38 PM
RE: Linux Images (ROCK64) - by xalius - 01-13-2018, 06:29 PM
RE: Linux Images (ROCK64) - by gene83 - 01-13-2018, 08:02 PM
RE: Linux Images (ROCK64) - by gene83 - 01-14-2018, 04:33 AM
RE: Linux Images (ROCK64) - by Luke - 01-14-2018, 08:58 AM
RE: Linux Images (ROCK64) - by thewonderer - 01-17-2018, 04:57 PM
RE: Linux Images (ROCK64) - by gene83 - 01-17-2018, 06:30 PM
RE: Linux Images (ROCK64) - by thewonderer - 01-17-2018, 06:45 PM
RE: Linux Images (ROCK64) - by gene83 - 01-17-2018, 11:06 PM
RE: Linux Images (ROCK64) - by a1w.ca - 01-17-2018, 11:52 PM
RE: Linux Images (ROCK64) - by Luke - 01-18-2018, 01:01 AM
RE: Linux Images (ROCK64) - by gene83 - 01-18-2018, 05:56 AM
RE: Linux Images (ROCK64) - by soichiro - 01-18-2018, 10:33 AM
RE: Linux Images (ROCK64) - by Luke - 01-18-2018, 10:38 AM
RE: Linux Images (ROCK64) - by soichiro - 01-18-2018, 11:07 AM
RE: Linux Images (ROCK64) - by thewonderer - 01-23-2018, 11:15 PM
RE: Linux Images (ROCK64) - by gene83 - 01-23-2018, 11:37 PM
RE: Linux Images (ROCK64) - by thewonderer - 01-24-2018, 12:16 AM
RE: Linux Images (ROCK64) - by matteobp - 01-24-2018, 03:35 AM
RE: Linux Images (ROCK64) - by ayufan - 01-24-2018, 10:07 AM
RE: Linux Images (ROCK64) - by matteobp - 01-25-2018, 04:54 AM
RE: Linux Images (ROCK64) - by matteobp - 02-06-2018, 11:02 AM
RE: Linux Images (ROCK64) - by thewonderer - 02-06-2018, 10:16 PM
RE: Linux Images (ROCK64) - by thewonderer - 01-24-2018, 05:27 PM
RE: Linux Images (ROCK64) - by Luke - 01-25-2018, 05:26 AM
RE: Linux Images (ROCK64) - by matteobp - 01-26-2018, 05:28 AM
RE: Linux Images (ROCK64) - by Luke - 01-26-2018, 06:04 AM
RE: Linux Images (ROCK64) - by gene83 - 01-25-2018, 05:39 AM
RE: Linux Images (ROCK64) - by Luke - 01-25-2018, 06:47 AM
RE: Linux Images (ROCK64) - by gene83 - 01-25-2018, 09:43 AM
RE: Linux Images (ROCK64) - by thewonderer - 01-25-2018, 04:34 PM
RE: Linux Images (ROCK64) - by Crady - 01-30-2018, 07:47 PM
RE: Linux Images (ROCK64) - by Luke - 01-31-2018, 01:33 AM
RE: Linux Images (ROCK64) - by gene83 - 02-06-2018, 12:59 PM
RE: Linux Images (ROCK64) - by gene83 - 02-07-2018, 08:43 AM
RE: Linux Images (ROCK64) - by Tony32 - 02-07-2018, 10:06 AM
Xenial Mate Cannot Install Add-ons - by Crady - 02-07-2018, 10:52 AM
RE: Linux Images (ROCK64) - by gene83 - 02-07-2018, 11:20 AM
RE: Linux Images (ROCK64) - by Crady - 02-07-2018, 11:47 AM
RE: Linux Images (ROCK64) - by gene83 - 02-07-2018, 02:04 PM
RE: Linux Images (ROCK64) - by Trash_Can_Man - 02-09-2018, 07:10 AM
RE: Linux Images (ROCK64) - by gene83 - 02-09-2018, 09:21 AM
RE: Linux Images (ROCK64) - by thewonderer - 03-01-2018, 08:29 PM
RE: Linux Images (ROCK64) - by prof7bit - 03-03-2018, 06:40 AM
RE: Linux Images (ROCK64) - by Ricky - 03-18-2018, 12:38 PM
RE: Linux Images (ROCK64) - by pfeerick - 03-18-2018, 09:15 PM
RE: Linux Images (ROCK64) - by Ricky - 03-19-2018, 07:04 AM
RE: Linux Images (ROCK64) - by t4_4t - 03-29-2018, 02:08 AM
RE: Linux Images (ROCK64) - by Malmgren - 04-02-2018, 05:30 AM
RE: Linux Images (ROCK64) - by WenYee - 04-08-2018, 02:38 AM
Linux Images (ROCK64) - by daniel.ligti - 05-06-2018, 01:40 AM
RE: Linux Images (ROCK64) - by rompelstompel - 05-14-2018, 04:38 AM
RE: Linux Images (ROCK64) - by jzhang18 - 05-29-2018, 01:20 PM
RE: Linux Images (ROCK64) - by evilbunny - 05-29-2018, 04:42 PM
RE: Linux Images (ROCK64) - by pfeerick - 05-29-2018, 05:27 PM
RE: Linux Images (ROCK64) - by jzhang18 - 05-31-2018, 07:43 PM
RE: Linux Images (ROCK64) - by pfeerick - 05-31-2018, 11:24 PM
RE: Linux Images (ROCK64) - by jzhang18 - 06-01-2018, 08:16 AM
RE: Linux Images (ROCK64) - by OnTheRocks - 05-30-2018, 03:52 AM
RE: Linux Images (ROCK64) - by evilbunny - 05-30-2018, 05:55 AM
RE: Linux Images (ROCK64) - by OnTheRocks - 05-30-2018, 09:13 PM
RE: Linux Images (ROCK64) - by evilbunny - 05-30-2018, 09:45 PM
RE: Linux Images (ROCK64) - by jzhang18 - 06-02-2018, 09:25 AM
RE: Linux Images (ROCK64) - by pfeerick - 06-02-2018, 10:50 PM
RE: Linux Images (ROCK64) - by t4_4t - 06-02-2018, 02:38 PM
RE: Linux Images (ROCK64) - by jzhang18 - 06-03-2018, 09:17 AM
RE: Linux Images (ROCK64) - by t4_4t - 06-04-2018, 01:25 AM
RE: Linux Images (ROCK64) - by jzhang18 - 06-04-2018, 02:38 PM
RE: Linux Images (ROCK64) - by jzhang18 - 06-05-2018, 10:14 AM
RE: Linux Images (ROCK64) - by gregb49 - 06-21-2018, 11:41 AM
RE: Linux Images (ROCK64) - by pfeerick - 06-21-2018, 06:07 PM
RE: Linux Images (ROCK64) - by gregb49 - 06-22-2018, 12:14 AM
RE: Linux Images (ROCK64) - by gregb49 - 06-22-2018, 12:25 AM
RE: Linux Images (ROCK64) - by pfeerick - 06-22-2018, 04:38 PM
RE: Linux Images (ROCK64) - by gregb49 - 07-17-2018, 10:23 AM
RE: Linux Images (ROCK64) - by Trash_Can_Man - 07-17-2018, 11:34 AM
RE: Linux Images (ROCK64) - by gregb49 - 07-17-2018, 01:03 PM
RE: Linux Images (ROCK64) - by Trash_Can_Man - 07-17-2018, 01:35 PM
RE: Linux Images (ROCK64) - by gregb49 - 07-17-2018, 04:16 PM
RE: Linux Images (ROCK64) - by Trash_Can_Man - 07-17-2018, 04:24 PM
RE: Linux Images (ROCK64) - by gregb49 - 07-18-2018, 02:46 AM
RE: Linux Images (ROCK64) - by gregb49 - 07-22-2018, 09:21 AM
RE: Linux Images (ROCK64) - by gene83 - 07-22-2018, 08:56 PM
RE: Linux Images (ROCK64) - by pineadmin - 08-06-2018, 02:30 AM
RE: Linux Images (ROCK64) - by gedas07 - 08-24-2018, 08:22 AM
RE: Linux Images (ROCK64) - by gene83 - 08-06-2018, 06:43 AM
RE: Linux Images (ROCK64) - by boudiicca - 08-06-2018, 08:15 AM
RE: Linux Images (ROCK64) - by ayufan - 08-06-2018, 11:32 AM
RE: Linux Images (ROCK64) - by AkiraSensei - 08-09-2018, 01:47 PM
RE: Linux Images (ROCK64) - by Averell - 09-12-2018, 06:02 AM
RE: Linux Images (ROCK64) - by evilbunny - 09-12-2018, 06:21 AM
RE: Linux Images (ROCK64) - by Averell - 09-26-2018, 05:31 AM
RE: Linux Images (ROCK64) - by evilbunny - 09-26-2018, 06:30 AM
RE: Linux Images (ROCK64) - by Averell - 11-01-2018, 12:47 PM
RE: Linux Images (ROCK64) - by thewonderer - 09-19-2018, 10:16 PM
RE: Linux Images (ROCK64) - by Luke - 09-20-2018, 04:00 AM
RE: Linux Images (ROCK64) - by thewonderer - 09-20-2018, 04:48 PM
RE: Linux Images (ROCK64) - by Averell - 10-17-2018, 07:26 AM
RE: Linux Images (ROCK64) - by Averell - 10-17-2018, 10:22 AM
RE: Linux Images (ROCK64) - by Averell - 10-18-2018, 06:37 AM
RE: Linux Images (ROCK64) - by thewonderer - 11-01-2018, 09:34 PM
RE: Linux Images (ROCK64) - by Averell - 08-18-2019, 12:18 AM
RE: Linux Images (ROCK64) - by kcirap - 08-26-2019, 05:52 PM
RE: Linux Images (ROCK64) - by fire219 - 08-26-2019, 06:11 PM
RE: Linux Images (ROCK64) - by kcirap - 08-26-2019, 09:28 PM
RE: Linux Images (ROCK64) - by kcirap - 08-30-2019, 05:08 PM
RE: Linux Images (ROCK64) - by dpgraham - 01-12-2020, 01:39 PM
RE: Linux Images (ROCK64) - by evilbunny - 01-12-2020, 07:52 PM
RE: Linux Images (ROCK64) - by dpgraham - 01-14-2020, 12:23 PM
RE: Linux Images (ROCK64) - by useful64 - 05-07-2020, 12:01 PM
RE: Linux Images (ROCK64) - by scalextrix - 05-05-2020, 12:22 PM
RE: Linux Images (ROCK64) - by vve1505 - 07-25-2020, 01:57 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 172 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,405 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 356 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 654 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 641 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,620 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 192,097 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 612 07-09-2023, 03:28 AM
Last Post: nemnob
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,788 06-02-2023, 07:52 AM
Last Post: diederik
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 670 05-27-2023, 06:11 AM
Last Post: Transportsicherung
