Problem with Pine
Hey
The 'zoom' is most likely overscan. Your best option to fix it is use your TV's and/or monitors over/underscan settings. These settings are called different things -- it will be easiest for you to google "overscan [make and model nr of your tv]" - on my TV (Sharp) its called dot per dot (not exactly intuitive).
The img you are using is pretty old - try one of the newer imgs. Check out longsleeps git: https://www.stdin.xyz/downloads/people/l...es/ubuntu/
Problem with Pine - by honkimonk1 - 10-08-2016, 05:10 PM
RE: Problem with Pine - by Luke - 10-11-2016, 09:03 AM
  Pine 1 will no longer boot (bricked) dstallmo 0 1,308 06-22-2023, 12:22 PM
Last Post: dstallmo
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 21,676 08-30-2020, 10:35 AM
Last Post: jrronimo
  Successful build on arm64 pine a64 1GB on armbian alladinrouteme 1 4,072 09-23-2019, 03:30 AM
Last Post: cr2016
  Pine hangs up on boot if I add my exFAT USB drive to /etc/fstab pqueiro 0 3,064 06-10-2019, 12:07 PM
Last Post: pqueiro
  Pine Board using linux stuck during boot sequence ktaragorn 0 2,822 03-23-2019, 04:06 AM
Last Post: ktaragorn
  PINE A64 upgrade to 18.04 possible? RandomUser324 4 9,380 11-29-2018, 11:46 PM
  Problem connecting to specific wifi network JamesWatt 1 4,662 07-03-2017, 02:09 PM
Last Post: ChristianC123
  Xenial Minimal Image (PINE A64(+)) 0.5.5-65 pineadmin 0 4,128 06-15-2017, 12:37 AM
Last Post: pineadmin
  Xenial Minimal Image (PINE A64(+)) 0.5.2-59 pineadmin 0 3,811 05-25-2017, 09:27 AM
  Pine as a Pi-hole ... Does that make it a PineHole? tomd 13 27,928 01-26-2017, 12:15 AM
Last Post: auger
