Pine Board using linux stuck during boot sequence
I hope this is the right section of the board, I have an issue with the original kickstarter version of PineA64. I am trying to use Xenial Minimal Image by long sleep to run on my board.
The board was running fine for years now, since shortly after i got it, using the originally supplied Ubuntu image originally, trimmed down into a server style setup. However suddenly it stopped working, and when I plugged in a display, I see that it is hung during boot, with a huge dmesg log displayed and ending with " Press enter to go into maintainence, or Control + D to continue " the words may not be exactly correct.. Pressing enter drops me into a console, while control D continues the freeze. After trying a couple of things, I decided to do a clean flash.. I got the image mentioned earlier by longsleep and flashed it with balena Etcher onto the sd card (this was also purchased along with the board itself). After this it boots fine, and when I try to setup a few things and reboot it, it comes to this hung state again. I was very happy with this board as a Fileserver/NAS setup and i hope it is possible to figure this out, but my fear is it might be a hardware issue.. or perhaps it is a SD card issue. It would be good if I could verify one or the other. I have attached 2 dmesg logs, both after a clean flash -> reboot. Attempt 1 Attempt 2
  Pine 1 will no longer boot (bricked) dstallmo 0 1,291 06-22-2023, 12:22 PM
Last Post: dstallmo
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 21,589 08-30-2020, 10:35 AM
Last Post: jrronimo
  Successful build on arm64 pine a64 1GB on armbian alladinrouteme 1 4,043 09-23-2019, 03:30 AM
Last Post: cr2016
  Pine hangs up on boot if I add my exFAT USB drive to /etc/fstab pqueiro 0 3,048 06-10-2019, 12:07 PM
Last Post: pqueiro
  +LTS/SOPINE Compilation procedure for U-Boot and Linux for pineA64 LTS. danpurprakash@gmail.com 1 4,148 06-05-2019, 11:50 PM
Last Post: igorp
  USB Wireless Drivers with Longsleep Linux Kernel jacobscarter 15 24,864 03-06-2019, 02:26 PM
  PINE A64 upgrade to 18.04 possible? RandomUser324 4 9,315 11-29-2018, 11:46 PM
  Resize /Boot mmcblk0p1 on SD? chadc 7 11,135 08-24-2018, 01:23 PM
Last Post: goathunter
Question Mali driver on linux? jamiechang917 8 11,391 03-04-2018, 03:01 PM
Last Post: Brian Beuken
  Ubuntu boot very slow with wifi driver remainder 9 20,813 08-03-2017, 07:23 AM
Last Post: victorssantos
