PINE A64 upgrade to 18.04 possible?
Currently running Xenial MATE 16.0 and am I trying 'do-release-upgrade' to 18.04 with no success on my Pine A64 (the original).   Wanted to confirm if anyone has done actually done this?     Was following instructions on the web like  (
https://forums.homeseer.com/forum/homese...-04-64-bit )   but then I realize that maybe pine64 and rock64 names are being mixed together.
Can someone confirm that what I'm attempting is indeed possible?
Update: It is possible. Read /var/log/dist-upgrade/main.log which showed a note about ubuntu-desktop. Google revealed having more than one desktop manager (mate-desktop and ubuntu-desktop) confuses the upgrade. Uninstalled ubuntu-desktop and retried was able to go through 'do-release-upgrade'. Now on 18.04, though by screen is blank after reboots, can access via SSH. One problem at a time I guess.
I take it there is no image for mainlne kernel -- or close to it, with a desktop and Mali support ...
Im amazed if there is not ... I have an Odroid-C2 that does ... but i need USB3.0 ...
I do have 18.04 Ubuntu but i cant seem to figure out to get it upgraded with out Wifi tools .... or wifi in general -- i use public Wifi for almost all internet stuff and i cant just walk up and grab a lan cable ...
I successfully upgraded mine to 18.04 a while back. I didn't have to do anything special, though 'man' was broken afterward. I documented that in this thread:
https://forum.pine64.org/showthread.php?tid=6453
Please check out ayufan github for PINE A64 updated Linux build: https://github.com/ayufan-pine64/linux-build/releases
  Pine 1 will no longer boot (bricked) dstallmo 0 1,291 06-22-2023, 12:22 PM
Last Post: dstallmo
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 21,590 08-30-2020, 10:35 AM
Last Post: jrronimo
  Successful build on arm64 pine a64 1GB on armbian alladinrouteme 1 4,043 09-23-2019, 03:30 AM
Last Post: cr2016
  Pine hangs up on boot if I add my exFAT USB drive to /etc/fstab pqueiro 0 3,048 06-10-2019, 12:07 PM
Last Post: pqueiro
  man breaks after upgrade to 18.04 goathunter 9 15,835 05-30-2019, 02:18 PM
Last Post: cr2016
  Pine Board using linux stuck during boot sequence ktaragorn 0 2,801 03-23-2019, 04:06 AM
Last Post: ktaragorn
  Xenial Minimal Image (PINE A64(+)) 0.5.5-65 pineadmin 0 4,114 06-15-2017, 12:37 AM
Last Post: pineadmin
  Xenial Minimal Image (PINE A64(+)) 0.5.2-59 pineadmin 0 3,790 05-25-2017, 09:27 AM
  Pine as a Pi-hole ... Does that make it a PineHole? tomd 13 27,768 01-26-2017, 12:15 AM
Last Post: auger
  Unable to start Pine Topgun505 16 17,864 11-13-2016, 12:01 AM
Last Post: Gnx
