Problem connecting to specific wifi network
I have ubuntu installed, this version:
ubuntu@pine64:~$ sudo uname -a
Linux pine64 3.10.104-2-pine64-longsleep #113 SMP PREEMPT Thu Dec 15 21:46:07 CET 2016 aarch64 aarch64 aarch64 GNU/Linux
I have 2 wifi networks at home as in some rooms wifi recption is poor.
I'm running the primary wifi on main internet router near the living room and a secondary wifi on an access point in one of the rooms with bad wifi.
I configured wifi in the living room on the primary wifi network, no problems at all wifi is working.
Then moved the pine to another room where it should use the secondary wifi.
Reconfigured wifi ssid (that is the only difference between both), but the pine won't connect.
I am sure both wifi networks work as other wifi clients (like phone, laptops, etc) have no problem connecting to either of them.
It's just the pine that won't connect to the secondary wifi.
Any suggestions on how to debug?
Thanks,
Eric
please try Native drivers and firmware
sudo apt-get install firmware-b43-installer
sudo apt-get purge bcmwl-kernel-source
reboot
Regards
Christian
http://cloudappsportal.com/
  Frustrations with Wifi, VNC, Longsleep, etc. NexusDude 1 6,135 06-05-2019, 11:43 PM
Last Post: igorp
  Connecting external monitor to the Pinebook Fox7799 0 4,756 04-21-2019, 01:14 PM
Last Post: Fox7799
  Issue with NTP (Network Time Protocol) and RTC (Real Time Clock), timedatectl emilhem 0 3,934 08-07-2017, 07:37 AM
Last Post: emilhem
  Ubuntu boot very slow with wifi driver remainder 9 27,361 08-03-2017, 07:23 AM
Last Post: victorssantos
  Problem with Pine honkimonk1 1 5,119 10-11-2016, 09:03 AM
Last Post: Luke
  dual wifi, one as access point vigor 0 3,613 09-02-2016, 11:55 PM
Last Post: vigor
  HDMI Overscan problem luke2389 8 16,859 09-02-2016, 10:22 PM
Last Post: Terra854
  Network Access Error coolnine98 5 11,534 06-29-2016, 06:15 PM
Last Post: coolnine98
  no network (dhcp) at work, all good at home. pineacle 1 4,381 06-28-2016, 10:13 PM
Last Post: pineacle
Question Set-up the wifi module jereze 9 24,373 05-18-2016, 12:02 PM
Last Post: jereze
