Pine 1 will no longer boot (bricked)
I have several Pine 1 boards.  In the process of setting Static IP addresses on one of the Pine 1 boards I have managed to brick it.  I have setup two other Pine 1 boards successfully so they book and I can ssh into them.  But in the third Pine 1 I have gotten it into a condition where the board comes up running Ubuntu using Ambian.  At boot a page of output appears in the HDMI console and then the screen goes black and ultimately shows a "No Signal" message.  I tried re-flashing the sd card I am booting from but had the same results.  Is there a way to return the board to the factory condition? Thanks for any help.
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 21,658 08-30-2020, 10:35 AM
Last Post: jrronimo
  Successful build on arm64 pine a64 1GB on armbian alladinrouteme 1 4,065 09-23-2019, 03:30 AM
Last Post: cr2016
  Pine hangs up on boot if I add my exFAT USB drive to /etc/fstab pqueiro 0 3,061 06-10-2019, 12:07 PM
Last Post: pqueiro
  +LTS/SOPINE Compilation procedure for U-Boot and Linux for pineA64 LTS. danpurprakash@gmail.com 1 4,171 06-05-2019, 11:50 PM
Last Post: igorp
  Pine Board using linux stuck during boot sequence ktaragorn 0 2,819 03-23-2019, 04:06 AM
Last Post: ktaragorn
  PINE A64 upgrade to 18.04 possible? RandomUser324 4 9,359 11-29-2018, 11:46 PM
  Resize /Boot mmcblk0p1 on SD? chadc 7 11,207 08-24-2018, 01:23 PM
Last Post: goathunter
  Ubuntu boot very slow with wifi driver remainder 9 20,891 08-03-2017, 07:23 AM
Last Post: victorssantos
  Xenial Minimal Image (PINE A64(+)) 0.5.5-65 pineadmin 0 4,128 06-15-2017, 12:37 AM
Last Post: pineadmin
  Xenial Minimal Image (PINE A64(+)) 0.5.2-59 pineadmin 0 3,811 05-25-2017, 09:27 AM
