SD card too small Error
I was yet another user frustrated by the android image files being to large for the intended SD cards.
After a lot of investigating and reading lots of similar posts and replies for the same issues, I found the answer.
Note: this works on Windows PC's, there is different solutions for Linux and OSX systems.
1) I'm assuming you have the downloaded img file and the required SD card. If not get them! Tongue
2) Download the IBEX file size changer. You can find it here
3) Run the program and select your img file. It will tell you the current file size. Enter a new file size into the target box. I found taking about 500M  off the current img file was enough on a 16G image. (for those wondering 155883011568 was the new file size Smile) Remove the check removed bytes tick. It's all empty space after the first gig roughly and if the rest of the image wasn't clean (non random data) it will just trigger an irrelevent error in this case.[Image: ibex_file_size_changer.png]
4) Use Rufus or Windisk imager as per before but now you should have not errors. Note: you may have to take a bit more off the file size if you have a card that does not have the full space usable due to errors etc.
This got me up and running pretty quickly with the LCD images. I hope it helps others as well.
SD card too small Error - by loungehound - 09-12-2016, 12:40 AM
RE: SD card too small Error - by Ghost - 09-12-2016, 12:50 AM
RE: SD card too small Error - by kenjiru - 11-27-2016, 04:50 AM
RE: SD card too small Error - by pfeerick - 11-27-2016, 08:47 PM
RE: SD card too small Error - by ayufan - 11-28-2016, 03:05 PM
RE: SD card too small Error - by projectrem - 01-19-2017, 01:26 AM
RE: SD card too small Error - by Bluphire - 01-21-2017, 05:37 PM
  Issues with SD Card and Running Android Twistedx 0 3,558 02-26-2019, 11:58 AM
Last Post: Twistedx
  Corrupt SD Card? CaptainCWA 13 16,962 06-04-2017, 08:01 PM
Last Post: pfeerick
  Error formatting MicroSD Terra854 21 39,406 03-07-2017, 01:31 AM
Last Post: AnaNova
  Editing SD card simplexdan 2 4,021 02-25-2017, 12:09 PM
Last Post: simplexdan
  android image & sd card size problems tomarneson 11 17,797 01-24-2017, 05:31 AM
Last Post: ayufan
  Creating bootable SD card on Mac OS X colinj 13 20,370 01-24-2017, 03:03 AM
Last Post: MarkHaysHarris777
  Netflix (v4.9.5) Error 1018 on Playback evanthor 3 15,998 12-19-2016, 09:24 AM
Last Post: Bluphire
  Corrupted SD card? Passiday 6 9,732 10-22-2016, 05:47 PM
Last Post: Ghost
  Setting up SD card and installing rooted Android using an ubuntu machine edszr.co 4 6,677 09-22-2016, 03:56 PM
Last Post: edszr.co
  Can't read SD card on Mac/Win after mounting DD Android image Voyager 3 5,518 09-04-2016, 12:05 PM
Last Post: Boring
