Can't read SD card on Mac/Win after mounting DD Android image
Last night I wrote the Android 5.1 DD image from the Pine 64 site to an 8GB PNY SD card using Win32 Disk Imager. I was then able to boot up Android on my Pine64 board without any issues. However, when I put the card back into my computer, I can no longer read anything on it. I get an error saying the inserted disk is not readable, both on my Windows and Mac machines.
How am I supposed to troubleshoot or make changes if I can't access the files on the disk? What should I do here?
(09-04-2016, 07:41 AM)Voyager Wrote: Last night I wrote the Android 5.1 DD image from the Pine 64 site to an 8GB PNY SD card using Win32 Disk Imager. I was then able to boot up Android on my Pine64 board without any issues. However, when I put the card back into my computer, I can no longer read anything on it. I get an error saying the inserted disk is not readable, both on my Windows and Mac machines.
Is it the rooted image?
... there will be somewhere between 10 and 20 partitions on that disk; some, if not all, will not have filesystems for you to mount !
If the system is rooted, you can move the files around, and edit them, and delete them, &c with apps like Better Terminal Pro, and others.
On mac download sd formatter. Even tho the mac wont "recognize" it the sd reader app will. After that select the sd card in the app and format itn works for me everytime
Sent from my SM-G928T using Tapatalk
As far as reading it im not to sure.
Use Linux to mount the sd card. Windows and Mac do not recognise the filesystem used by android.
https://en.m.wikipedia.org/wiki/File_system
Your Android image should work fine.
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 388,317 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,670 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,825 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,988 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,053 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,614 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,340 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 258,572 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,548 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,201 02-10-2019, 07:44 PM
Last Post: mmmarcus
