Setting up SD card and installing rooted Android using an ubuntu machine
Hi There,
I've looked for an answer to this and didn't see one.  Sorry if I missed it.  I would like to install rooted android on my pine 64, but the only info I've seen about doing this shows how to do it from a windows machine.  I'm currently using ubuntu 16.04.  Is there a way to install rooted android onto the pine64 without using windows?
thanks,
Ed
(09-22-2016, 09:40 AM)edszr.co Wrote: Hi There,
thanks,
Ed
Hi.
Yes, by selecting the appropriate rooted image and using the dd command, or if you prefer a graphical user interface, you could download Etcher.
Thanks Ghost. Etcher is really cool and easy to use. Now I've got another problem. I have a 64gb micro sd card, but formatted it only has ~59 gb of space. So etcher tells me my rooted 64gb android image won't fit. Should I try a smaller image?
thanks again for the help!
(09-22-2016, 12:39 PM)edszr.co Wrote: Thanks Ghost.  Etcher is really cool and easy to use.  Now I've got another problem.  I have a 64gb micro sd card, but formatted it only has ~59 gb of space.  So etcher tells me my rooted 64gb android image won't fit.  Should I try a smaller image?
Yes, the latest Android images are slightly mis-sized. For argument's sake, try a smaller image just to get things working.
More suitable OS images are forthcoming.
Thanks Ghost.  I''m back in business.  I appreciate the help and patience Wink
Ed
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 389,114 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,767 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,867 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,001 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,079 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,630 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,351 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 259,074 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,556 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,424 02-10-2019, 07:44 PM
Last Post: mmmarcus
