Error formatting MicroSD
When I tried to format my 16GB MicroSD card using the latest android image and Phoenixcard, it gave out a "card preprocess failed 228" error.
Can anyone help me fix this?
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
I got an error the first time I tried. You HAVE to use an external card reader. The first time I plugged it into the computer and nothing. Tried the external and it worked fine. Maybe that will help.
Sent from my iPod touch using Tapatalk
Try to use a program like SD Formatter then try to burn the image with Phoenixcard.
skybadiver, I too had great success with an external card reader. I also found that it is picky about SD Card Adapters, when I tried multiple brands.
I got lucky with my one sd card reader! Thank goodness!
Ok... now I have switched to an external SD card reader and now this happened:
So what is the problem now?
(03-20-2016, 03:02 AM)Terra854 Wrote: So what is the problem now?
Maybe a faulty/fraud card. I would never ever use any flash based media before checking it for errors and if it's a fake card (quite common):
Background information and necessary tools here: http://oss.digirati.com.br/f3/
I had an issue with creating a boot SD card as well. I found that by using the windows troubleshoot compatibility wizard helped me and set the program to run like it was windows 8. (I have windows 10) So I wonder if there is an issue with phoenixcard and windows 10
(04-03-2016, 12:07 PM)mhump711 Wrote: I had an issue with creating a boot SD card as well. I found that by using the windows troubleshoot compatibility wizard helped me and set the program to run like it was windows 8. (I have windows 10) So I wonder if there is an issue with phoenixcard and windows 10
I use several win 10 machines with phoenixcard and works. However, I will check with Allwinner on this question when meet up with their engineer on next week.
Wasn't trying to imply that there is an issue between the 2 but I just wanted to let people know what I did in order to get it to work. But thanks for the quick reply
Just tried it again. It was all a fluke. I still have issues getting it to write to the card successfully. I just kept trying and it eventually worked again.
  SD card too small Error loungehound 7 12,673 01-21-2017, 05:37 PM
Last Post: Bluphire
  Netflix (v4.9.5) Error 1018 on Playback evanthor 3 15,998 12-19-2016, 09:24 AM
Last Post: Bluphire
  MicroSD Size mismatch with Image Hbtr 23 28,510 08-31-2016, 09:00 AM
Last Post: montero65
  Change MicroSD card AA666 2 4,484 05-26-2016, 01:20 PM
Last Post: AA666
