Switching from touchscreen to HDMI
(08-11-2016, 05:56 AM)xalius Wrote: Hi, where are you stuck with building a Linux kernel? Are you building a BSP kernel based on longsleep's work or a mainline kernel based on linux-sunxi ?
You can find longsleep's kernel work at his github, it's the basis for running his Ubuntu images or lenny's Debian images or my Gentoo test image as well as info on how to build the different firmwares needed to boot A64 here:
https://github.com/longsleep/build-pine64-image
https://github.com/longsleep/linux-pine64
This is based on the 3.10.x BSP kernel release from Allwinner's Linux SDK, with some community fixes and forwarded to 3.10.102 by longsleep.
For mainline kernel you need to have a look at the linux-sunxi community:
https://linux-sunxi.org/Main_Page
https://linux-sunxi.org/Linux_mainlining_effort
https://linux-sunxi.org/Pine64
Fire219 build some test images for 4.7 you can use headless for testing stuff (mainline doesn't have a video driver yet) with GbE, USB and some low-level interfaces already.
Yeah, a bit of topic --- but --- I've tried the longsleep build.  Did all the pulls, etc.  Followed the steps.  May have had trouble with busybox - as when I 'cpio'd my initrd to check the files, I got total garbage.  Found another git that had a "one-shot" script to do the whole thing.....  May try that Friday night.  If nothing else, I can try a different prebuilt initrd image.
I got the linaro aarch64 gnu toolchain 4.9 and the 5.3 arm toolchain.   Put the whole thing in docker.  The idea is to set up a docker container to build the whole thing --- if I can, I'll publish my docker images.
More on topic, though, NVidia has a public git for the open source stuff on the shield controller (that does the HDMI/LCD switch).  May get some ideas out of that.
--Ken
Switching from touchscreen to HDMI - by AUDIOTEK - 08-06-2016, 03:20 PM
RE: Switching from touchscreen to HDMI - by tllim - 08-07-2016, 02:51 PM
RE: Switching from touchscreen to HDMI - by tllim - 08-07-2016, 05:47 PM
RE: Switching from touchscreen to HDMI - by blackt1ger - 08-11-2016, 07:24 PM
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 623 04-29-2023, 05:13 AM
Last Post: burningkrome
  lcd touch screen and hdmi output moreaujacky 2 5,101 10-24-2018, 07:24 AM
Last Post: lisanke
  No HDMI Display need help with correct uEnv.txt settings dkebler 7 10,648 01-11-2018, 02:52 PM
Last Post: dkebler
  HDMI Compatability rahlquist 5 8,286 07-29-2017, 02:32 AM
Last Post: qwerty2002
  Ongoing HDMI limited compatability rahlquist 39 50,774 05-21-2017, 12:59 PM
Last Post: lbdroid
  No HDMI Output martinarcher 2 6,691 04-28-2017, 07:05 AM
Last Post: martinarcher
  Switching boot source on SOPINE64 stephen fleming 2 3,807 03-07-2017, 07:02 AM
Last Post: xalius
  Integration with E-Ink Touchscreen adamjedgar 3 5,850 02-16-2017, 04:56 AM
Last Post: adamjedgar
  4K HDMI video output medapeta 3 6,742 06-10-2016, 04:36 PM
Last Post: shinobi
  HDMI Issue... LeRoms77 4 7,394 04-19-2016, 02:11 AM
Last Post: LeRoms77
