03-07-2017, 12:09 AM
How will the selection of boot source be handled on the SOPINE64? I do not see a switch or jumper on the baseboard or module board to switch between a micro SD card and a eMMC card.
Switching boot source on SOPINE64
03-07-2017, 12:53 AM
The boot source will be the SD card; the /rootfs can run from the eMMC.
marcushh777
please join us for a chat @ irc.pine64.xyz:6667 or ssl irc.pine64.xyz:6697 ( I regret that I am not able to respond to personal messages; let's meet on irc! )
The A64 will probe the mmc/spi interfaces in a set sequence, sdcard has priority over eMMC, so it depends where you have a valid boot0/spl loader. You can also install u-boot into the SPI flash and boot from network or USB for example. If no valid boot source is found, it will fall back into FEL bootloader mode which is communicating viat the USB OTG port. This can be used to upload u-boot for example and then boot or expose eMMC as USB mass storage...
Code: boot-> check fel key pressed (yes)--> FEL mode (boot from USB OTG)
Come have a chat in the Pine IRC channel >>
| PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot | burningkrome | 3 | 6,242 |
05-19-2023, 07:43 AM Last Post: crocspot |
| Pine A64 does only boot with Android 5.1 | Dude | 6 | 10,386 |
07-03-2022, 02:18 PM Last Post: Dude |
| Pine A64+ vs LCD do not boot | DDS | 3 | 10,656 |
02-23-2021, 05:33 PM Last Post: thedu |
Can't boot when SD card inserted | kivox | 5 | 12,681 |
03-15-2020, 06:00 AM Last Post: kivox |
| Boot from HDD via usb | BnEc | 1 | 5,628 |
11-29-2019, 04:39 AM Last Post: evilbunny |
| Pine A64 stuck in boot process | joey | 1 | 5,405 |
05-28-2019, 09:07 PM Last Post: joey |
| Won't power on/boot -- kickstarter A64 2GB | fuzzycuffs | 3 | 9,649 |
02-22-2019, 03:25 AM Last Post: GaryFunk |
| boot loop with lcd plugged in | drock | 0 | 3,341 |
01-09-2019, 01:37 AM Last Post: drock |
| LED flashes for 1 second, board won't boot | Audioslave | 2 | 6,779 |
08-02-2018, 10:28 PM Last Post: tllim |
| short boot time after power-up | bongo | 7 | 16,403 |
10-31-2017, 08:02 AM Last Post: bongo |
