LED flashes for 1 second, board won't boot
I've been using an A64+ 2GB board since January 2017 as a headless NAS. It's been running with the same power supply and overall setup for essentially the entire time.
The other day, I couldn't SSH into the board. I noticed the LED was off, so I unplugged/replugged the USB power supply.
The LED comes on for about 1 second, shines brighter for a brief moment, then shuts off. The board doesn't boot at all. I've hooked up a monitor and get no output.
If I eject the microSD card, the LED stays on. If I power on without the microSD, then insert it after powering on, the LED stays on, but it doesn't read the card and boot.
I'm kind of at a loss for troubleshooting from here and would appreciate any thoughts. Thank you.
(07-31-2018, 08:04 PM)Audioslave Wrote: I've been using an A64+ 2GB board since January 2017 as a headless NAS. It's been running with the same power supply and overall setup for essentially the entire time.
Mine has the red LED always on, however still on without microSD inserted.
Could you try to get more info using FTDI console ?
Which distro are you running ?
The power LED connected directly to 5V DC in. If you have another power supply handy, please try out. My guess may be s]power supply issue.
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 6,769 05-19-2023, 07:43 AM
Last Post: crocspot
  Pine A64 does only boot with Android 5.1 Dude 6 11,010 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 11,189 02-23-2021, 05:33 PM
Last Post: thedu
  How to build Webradio from Board A64 ? Bebert 5 12,839 08-19-2020, 12:49 PM
Last Post: Bebert
Exclamation Can't boot when SD card inserted kivox 5 13,254 03-15-2020, 06:00 AM
Last Post: kivox
  Boot from HDD via usb BnEc 1 5,970 11-29-2019, 04:39 AM
Last Post: evilbunny
  PINE64 board not powering up loki21century 2 9,152 11-25-2019, 12:19 PM
Last Post: Partymack711
  Pine A64 stuck in boot process joey 1 5,709 05-28-2019, 09:07 PM
Last Post: joey
  Won't power on/boot -- kickstarter A64 2GB fuzzycuffs 3 10,110 02-22-2019, 03:25 AM
Last Post: GaryFunk
  boot loop with lcd plugged in drock 0 3,593 01-09-2019, 01:37 AM
Last Post: drock
