PINE64 board not powering up
Hi all,
I have just purchased a new Pine64 board with 2gb ram and a new power supply.  I powered it up and installed OVM  on it.  It was running fine for 4 hours and then it switched itself off.  The board is no longer powering up, the on board red light is not coming on.  I've disconnected everything and re attached it all again and plugged the power supply into the power socket and switched on but nothing. Would anyone be able to assist.
(09-20-2019, 04:29 AM)loki21century Wrote: Hi all,
If red LED (power LED) is not light up, this means the PINE A64 doesn't received power and most likely is power supply issue. Please make sure that your power is 5V 2A or above type.
i have been having a similar issue to this.
sometimes my PineA64 does not boot and on pressing the power button displays the red light fir a few seconds and then it goes off.
I have noticed if I unplug the power cable from the board and then plug it back in it will boot fine.
I am using Volumio but this also occurred with Android. I am using the original powers supply that was shipped with the board so I assume no issues here.
any ideas?
Question External storage problem for pine64 Dani6102 3 7,502 07-26-2023, 10:57 AM
  Pine64 as wireless audio device S265 3 9,667 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 4,782 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 45,894 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 5,834 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 5,700 09-14-2020, 09:55 AM
Last Post: PaddyChan
  How to build Webradio from Board A64 ? Bebert 5 13,092 08-19-2020, 12:49 PM
Last Post: Bebert
  Pine64 OS dpcons 2 8,054 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 6,106 02-17-2020, 11:39 PM
Last Post: vj-kumar
  Pine64 not powering up. skylab 5 13,318 05-03-2019, 02:48 PM
Last Post: Mendota
