External storage problem for pine64
Question
Hi there!
I have recently bought a pine64 and i am using it as a plex server with USB-stick as extra drive to not fill the sd card, unfortunately when i tried to connect a 1tb 2,5 HDD from seagate it wasn't reading it's content, from searching online i found out that the usb2.0 do not provide enough power, and i was now wondering if they could support an SSD or if i need to buy an usb hub.
do you have any suggestion about my problem?
thanks!
a 2.5" SSD should only draw about 5v, which is the max USB2 can supply, but if you're able you could grab an nvme+usb case/adapter and it would likely only be pulling about 3.3v, with some wiggle room for usage peaks. either form of SSD or a powered usb hub should work for your use case.
(07-26-2023, 08:34 AM)tophneal Wrote: a 2.5" SSD should only draw about 5v, which is the max USB2 can supply, but if you're able you could grab an nvme+usb case/adapter and it would likely only be pulling about 3.3v, with some wiggle room for usage peaks. either form of SSD or a powered usb hub should work for your use case.
thanks for the response, i tried plugging in a 120gb ssd but it is not recognized as sd*1 so i think i need to go with an usbhub or an nvme, do you or anyone who will read this post have any suggestion for a cheap nvme+adapter combo or a decent hub?
i use the ElecGear NV-2242A nvme enclosure on the daily. it's solidly built and the magnetic cap is extremely convenient. i don't recall which nvme i have in it, but i think it's either a 2242 Sabrent 512GB Rocket or a 2242 MyDigitalSSD Super boot 2. as far as a hub, any that handles usb2 and has a wall wart for additional power should work just fine.
Well, I will recommend you to choose the one of the best option i.e. consideration of SSD which is extremely fast and less power consuming.
  Jack connector problem pinebug 0 1,553 11-10-2022, 01:46 PM
Last Post: pinebug
  Pine64 as wireless audio device S265 3 3,321 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 1,174 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 28,944 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 3,144 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 2,795 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Pine64 OS dpcons 2 4,989 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 2,854 02-17-2020, 11:39 PM
Last Post: vj-kumar
  PINE64 board not powering up loki21century 2 5,629 11-25-2019, 12:19 PM
Last Post: Partymack711
  Pine64 not powering up. skylab 5 7,309 05-03-2019, 02:48 PM
Last Post: Mendota
