Pine64 not powering up.
Hello everyone, I have a Pine64-db rev b i bought a while ago, i've never used it and it was sitting in the static bag , i now decide to use it with
octoprint for my 3d printer and i applied power and while the monitor get drive for a few seconds, it reverts to no signal present , only the power
led is illuminate , the usb keyboard led flashes when power is applied but thats it..it sits there dead..nothing , can anyone help me how to proceed
from here.
you need a good power supply. probably 2amp. you would be best to have ethernet connected at 1st boot. if i remember you need a monitor that does 720p or 1080p. it can stall if you do not have ethernet. then just have kb/mouse. it takes a while for 1st boot. what you experience is a common experience. if it persists try powering it via the pins. the usb power socket is lame.
(02-26-2019, 09:50 AM)dkryder Wrote: you need a good power supply. probably 2amp. you would be best to have ethernet connected at 1st boot. if i remember you need a monitor that does 720p or 1080p. it can stall if you do not have ethernet. then just have kb/mouse. it takes a while for 1st boot. what you experience is a common experience. if it persists try powering it via the pins. the usb power socket is lame.
Thank you for the reply i'm currently using a 5V 2.5Amp psu , i had an hdmi->dvi adapter connected and the monitor got drive, i also switched to a TV set with hdmi
and the same thing..no display , just a drive signal and then back to no signal, i however didnt have the ethernet connected as i was hoping to use wifi.. i will try with this and report
back.. thanks again.
as i recall the dvi-hdmi did not work except in a limited number of setups with a certain type of dvi-hdmi adapter, don't remember the details. also, tv sets were problematic for some reason. it's all here in the forum if you care to search, but a straight hdmi monitor with 720p or 1080p is best bet. this pine64 board can be a frustrating beast until you get to know the ins & outs. good luck.
Reporting back: so i connected the Ethernet and DVI->HDMI and behold she powers up..only to be faced with another error
but this is related to the image i downloaded i suspected , but i wanted to thank you for your guidance. i'll try another image
and see if i can get a terminal or desktop and work from there..i can now justify buying another board for my openHAB..
I had a similar issue. It happened because my husband attempted to turn it on with the battery dead. It would light up green on the base and the screen would flicker and then go out. I fixed it by hold down the power button, it then booted all the way up with me holding the button. After it made it to the desktop I selected shut down and it powered down and the indicator lit up red and it began charging.
Lithium batteries do not like to be run down to zero. Thought I would post this in case someone else ran into the same issue.
Question External storage problem for pine64 Dani6102 3 7,543 07-26-2023, 10:57 AM
  Pine64 as wireless audio device S265 3 9,733 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 4,801 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 45,972 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 5,852 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 5,735 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Pine64 OS dpcons 2 8,071 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 6,130 02-17-2020, 11:39 PM
Last Post: vj-kumar
  PINE64 board not powering up loki21century 2 9,341 11-25-2019, 12:19 PM
Last Post: Partymack711
  Pine64 LTS vs Rock64 4 GB LTS gops 2 7,406 04-15-2019, 10:56 AM
Last Post: gops
