Pine64 LTS vs Rock64 4 GB LTS
I needed boards for industrial use, we are rolling out a simple monitoring services, decided to use boards from Pine community.
We have one questions, Pine64 LTS vs Rock64 4 GB LTS? Which one to choose? I see that Pine64 LTS has mentioned one year warrentee which is a good sign, but same is not applicable for Rock64.
Can you please recommend one?
What exactly do you need it for? how will the monitors connect ? what OS will you want to run?
(04-15-2019, 05:48 AM)Luke Wrote: What exactly do you need it for? how will the monitors connect ? what OS will you want to run?
1. We need for reading data from PLCs and sensors.
2. HDMI expected to connect
3. We will use Linux Debian derivatives are fine. Having a browser is a simple requirement, as they can see the dashboards live on TV in front of assembly line if they want. Otherwise a Java Program, running and collecting production data, report to other servers on network.
We are not doing DIY kind of work [we already done prototypes], now customers wants products.
These boards used for monitoring PLCs, so customers not interested in heavy amount for monitoring work, as they already invested heavily into PLCs and other systems. Honestly speaking, reading few modbus registers over RS 485 should be expensive for them too, rest of the work is taken care by the cloud. We also now building few extension boards for Raspberry PI compatible extentions which can extends more UARTS to RS 485/RS 232.
We are running few Raspberry PIs in industrial monitoring with ambient environments, we haven't faced any problems, running 24/7 with heavy workload, added heat sink, the temp is about 40-50 range only. Some features of our apps needs much higher RAM, sometimes 1 GB was not enough to handle DB, acquisitions, in memory computations.
We are targeting < 100 USD boards, range from 60 USD to 100 USD, where as our competitions has 400 USD to 500 USD boards, which our customers doesn't want.
I see a trend nowadays, most of the industrial boards on budget level are sold out very fast, I wish Pine team can do something for industrial. For Industries, you need more UARTS, USBs, Ethernet PORTS, less of graphics/videos stuffs.
Question External storage problem for pine64 Dani6102 3 7,632 07-26-2023, 10:57 AM
  Pine64 as wireless audio device S265 3 9,823 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 4,860 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 46,204 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 5,905 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 5,810 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Pine64 OS dpcons 2 8,128 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 6,204 02-17-2020, 11:39 PM
Last Post: vj-kumar
  PINE64 board not powering up loki21century 2 9,390 11-25-2019, 12:19 PM
Last Post: Partymack711
  Pine64 not powering up. skylab 5 13,399 05-03-2019, 02:48 PM
Last Post: Mendota
