PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot
I have a Pine64 from the original Kickstarter (2016.) It boots from a 32GB SD card, which I've imaged from an Ubuntu16 Pine64 image file.
I've created a full disk backup of this 32GB SD card using AOMEI Backupper, and then restored the entire disk to a new 64GB SD card. The restore is successful, and the disk looks OK, but the 64GB card won't boot. Putting it in the Pine64 and powering on simply remains at a black screen (the original SD boots as soon as I plug the Pine64 in. I don't have to press a "Start" button or anything.)
I have also tried this with a 256 SD card, with the same results.
I have tried copying the entire 32GB SD card with DD in linux, and restoring via DD. Same problem.
What am I missing. Does the new disk have to have a boot sector activated or something?
I absolutely can't see the difference (see image for full details about the drive and copy)...
[Image: 6rXMvv3]
https://ibb.co/6rXMvv3 (If image link is broken)
(05-06-2023, 06:01 AM)burningkrome Wrote: I have a Pine64 from the original Kickstarter (2016.) It boots from a 32GB SD card, which I've imaged from an Ubuntu16 Pine64 image file.
[Image: 6rXMvv3]
You best ask in the community channel for help: https://wiki.pine64.org/wiki/Main_Page#C...nd_Support
I have edited your title and moved the post into the correct section, otherwise no one will find it.
@crocspot , I have removed your reply since the question was about the PINE A64 SBC, not a PinePhone.
Do you still have the original image? If you write it to a new 32GB card, does that work? If you write it to a 64GB card, does that work?
:wq
[ SRA accepts you ]
Apologies @fxc
Sorry about that miss post all !
It was "very" early in the morning after a late night and for some crazy reason I miss read it as a Pine Phone problem.
Thanks for cleaning my "mess" up and the moderation
All the best
Cool
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 610 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 3,958 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 5,994 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 3,353 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 4,513 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 7,803 12-06-2020, 03:53 PM
Last Post: junkyj753
Exclamation Can't boot when SD card inserted kivox 5 8,092 03-15-2020, 06:00 AM
Last Post: kivox
  Node Red on the Pine DonFL 0 2,786 12-16-2019, 04:21 PM
Last Post: DonFL
Photo Pine A64+ from Kick starter running Pi-Hole netHolio 0 3,252 12-02-2019, 09:36 PM
Last Post: netHolio
  Boot from HDD via usb BnEc 1 3,730 11-29-2019, 04:39 AM
Last Post: evilbunny
