Boot Order in Pinebook Pro
If you have the uboot image (uboot.img OR u-boot.itb) then, to find out,
strings <uboot> |grep _targets replacing <uboot> with whatever is appropriate
mmc0 is emmc, mmc1 is SD
OR using dd, rip 4M out of some block device starting 8M in (and writing to some tmp file)
what you want is
strings uboot.img |grep _targets
boot_targets=mmc1 usb0 mmc0 pxe dhcp
(this from mrfixit bsp uboot,, no nvme)
Of course there has to be the boot files in "correct" place, one of,,,, boot.scr, extlinux.conf, aarch64.efi
and their configuration has to be correct too
--------after a little more thought----
Maybe for the OP, easiest would be to rename the boot files and see what happens,, ie
cd /boot/extlinux ; mv extlinux.conf extlinux.conf.good ;reboot (reboot is a little flakey, might need a shutdown)
Obviously with SD card in
Boot Order in Pinebook Pro - by food - 11-17-2023, 06:21 AM
RE: Boot Order in Pinebook Pro - by wdt - 11-18-2023, 12:55 PM
RE: Boot Order in Pinebook Pro - by donn - 11-18-2023, 07:03 PM
RE: Boot Order in Pinebook Pro - by wdt - 11-18-2023, 08:41 PM
RE: Boot Order in Pinebook Pro - by donn - 11-20-2023, 07:02 AM
RE: Boot Order in Pinebook Pro - by food - 11-22-2023, 07:04 PM
RE: Boot Order in Pinebook Pro - by donn - 11-23-2023, 03:51 AM
RE: Boot Order in Pinebook Pro - by KC9UDX - 11-22-2023, 10:08 PM
RE: Boot Order in Pinebook Pro - by KC9UDX - 11-23-2023, 07:37 AM
  Debian on Pinebook Pro u974615 7 1,571 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 2,100 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,343 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,472 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 91,055 12-08-2023, 11:25 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,685 08-31-2023, 04:20 PM
Last Post: TRS-80
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,072 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,678 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,785 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 746 07-13-2023, 05:21 PM
Last Post: owaspfap
