Bogus default gateway keeps appearing
maybe you should check files and contents in directory tree "/etc/network/". maybe there is something fishy.
check using command (sudo) "nmtui", if there is weird settings.
RE: Bogus default gateway keeps appearing - by zetabeta - 02-23-2023, 12:22 AM
  4G data on default startup / boot dcinoz 1 888 04-29-2023, 11:24 PM
Last Post: dcinoz
  Change default program for a file type 3x5co 1 1,810 09-01-2021, 05:26 PM
  Default SMS app send button off screen in vertical orientation motox6 0 1,270 05-22-2021, 02:55 PM
Last Post: motox6
  Desktop Entry icon not appearing: how to diagnose? Saliency 6 5,248 03-15-2021, 05:49 AM
Last Post: kqlnut
  Make 'terminal' on-screen keyboard the default 3x5co 0 1,853 12-27-2020, 05:11 PM
Last Post: 3x5co
  ssh not enabled, by default? RodMyers 6 6,104 10-02-2020, 07:35 AM
Last Post: LinAdmin2
  sudo / lock screen password keeps resetting to default ergo owl 6 7,014 09-04-2020, 06:07 AM
Last Post: ergo owl
  How to change the minimum password length when changing from default passwords arturo2bodegas 3 4,636 07-18-2020, 01:51 PM
Last Post: arturo2bodegas
  Default Theme wasgurd 4 6,121 06-26-2020, 06:28 PM
Last Post: wasgurd
