ssh not enabled, by default?
Did a fresh install of mobian. Trying to ssh into the phone.
following the wiki -> https://wiki.mobian-project.org/doku.php...f-password <- it seems that the ssh_server is not installed and running.
From within the phone & gui , I do not see anything to do with the ability to log into the phone.
What program(s) need to be installed to be able to ssh into the phone?
thanks
'sudo apt install openssh-server' should do it.
Edit: ... and the terminal program is called King's Cross for some reason. Smile
(09-14-2020, 12:26 PM)bitnick Wrote: 'sudo apt install openssh-server' should do it.
Thank you. Will get it installed
Thank you, worked for me.
Just wondering why they do not include it in their image?
Probably because it's a security risk (an additional attack surface, and a rather weak one if you use the four-digit passcode to login), and something that not everyone will want to use.
I agree with @bitnick - if you're going to use sshd you should disable password login and use keys. See https://wiki.mobian-project.org/doku.php?id=security for quick instructions. The PmOS build script offers to do this for you.
(10-02-2020, 04:20 AM)bitnick Wrote: Probably because it's a security risk (an additional attack surface, and a rather weak one if you use the four-digit passcode to login), and something that not everyone will want to use.
I do not think that on a gadget usable only for playing around any reasonable person would store confidential data Blush
  4G data on default startup / boot dcinoz 1 841 04-29-2023, 11:24 PM
Last Post: dcinoz
  Bogus default gateway keeps appearing Zebulon Walton 7 2,212 02-25-2023, 09:48 PM
  Modem suddenly not enabled when booting from eMMC Zebulon Walton 3 2,676 10-23-2021, 01:55 PM
  Change default program for a file type 3x5co 1 1,761 09-01-2021, 05:26 PM
  Default SMS app send button off screen in vertical orientation motox6 0 1,243 05-22-2021, 02:55 PM
Last Post: motox6
  Make 'terminal' on-screen keyboard the default 3x5co 0 1,822 12-27-2020, 05:11 PM
Last Post: 3x5co
  sudo / lock screen password keeps resetting to default ergo owl 6 6,878 09-04-2020, 06:07 AM
Last Post: ergo owl
  How to change the minimum password length when changing from default passwords arturo2bodegas 3 4,553 07-18-2020, 01:51 PM
Last Post: arturo2bodegas
  Default Theme wasgurd 4 6,020 06-26-2020, 06:28 PM
Last Post: wasgurd
