sudo / lock screen password keeps resetting to default
This is the second time I have installed mobian on the eMMc of my Pinephone UBPorts Edition.
The first time I changed the password from the default "1234" using the terminal emulator with the
command "sudo passwd" and it worked.
However, after making some annoying changes I couldnt revert, I decided to reinstall everything and now,
when I try to change the password in the terminal emulator using the same command "sudo passwd", it says:
passwd: password updated successfully
But, when I lock the screen and then attempt to unlock it with the new password. It doesnt work.
When I try with the default "1234" password it works like if I had never changed it "successfully".
Not sure what is happening or what Im doing wrong, maybe Im just tired. Any ideas?
Reboot.
(09-03-2020, 08:59 AM)jed Wrote: Reboot.
Yeah that doesnt fix anything for me. When I type the password I "successfully" set in the terminal it reads "Checking..." and then fails to unlock.
I put the original passcode "1234" and the screen unlocks.
how about sudo passwd mobian, or just passwd (think you need the sudo to avoid moans about numeric only password?)
(09-03-2020, 12:37 PM)dukla2000 Wrote: how about sudo passwd mobian, or just passwd (think you need the sudo to avoid moans about numeric only password?)
Yep.
Not anymore Wink
Yes!! It worked!
sudo passwd mobian
Thank you, this was annoying me so much lol.
  Screen auto-rotation sensitivity mdk 0 268 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 652 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,200 06-22-2023, 11:20 AM
Last Post: Melechtna
  4G data on default startup / boot dcinoz 1 841 04-29-2023, 11:24 PM
Last Post: dcinoz
  Bogus default gateway keeps appearing Zebulon Walton 7 2,211 02-25-2023, 09:48 PM
  Lock screen question: always squeekboard tuxcall 1 1,233 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,017 01-13-2023, 03:33 AM
Last Post: mdk
  how to split screen? andrew907 2 1,530 08-08-2022, 09:38 AM
Last Post: andrew907
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,810 08-02-2022, 03:16 PM
Last Post: treebeard
  on screen keyboard woes vusra 1 1,247 07-18-2022, 03:29 AM
Last Post: vusra
