Screen stay black unless power key pressed short
Hi all,
Few times the screen stay black when i short pressed power key.
The first situation let thinking about SWAP problem.
juin 24 07:51:53 mobian kernel: get_swap_device: Bad swap offset entry e80000cbfd8f
The problem appear line 6694 until the end of file 700038.
https://debian-facile.org/paste-D2EF27DD...8e0853f531
The second situation, you can analyze the journalctl log at the end line 8074.
This is at this step i tried to press power key short to wake-up my pinephone.
https://debian-facile.org/paste-867262EE...32f07ffd6d
I have seen this two lines, but maybe it's not their.
juin 24 15:30:34 mobian gsd-xsettings[1224]: Failed to get current UI legacy scaling factor
juin 24 15:30:32 mobian kernel: Freezing remaining freezable tasks
If you have an idea about this problem ! Thank you a lot
  Screen auto-rotation sensitivity mdk 0 273 12-26-2023, 06:08 AM
Last Post: mdk
  Power Consumption on Suspend JudgeFudge 8 1,871 07-29-2023, 06:24 AM
Last Post: JudgeFudge
  Unsuspend → Black screen mdk 15 5,218 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 1,233 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,017 01-13-2023, 03:33 AM
Last Post: mdk
  how to split screen? andrew907 2 1,538 08-08-2022, 09:38 AM
Last Post: andrew907
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,819 08-02-2022, 03:16 PM
Last Post: treebeard
  on screen keyboard woes vusra 1 1,251 07-18-2022, 03:29 AM
Last Post: vusra
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 858 07-17-2022, 10:34 AM
Last Post: 3x5co
  Won't boot, black screen mdk 4 2,739 07-03-2022, 06:38 PM
Last Post: Chief
