how to split screen?
I am comfortably set up with a Pinephone running Mobian and a Bluetooth keyboard, but it would sure be nice to be able to see two apps at the same time like in Ubuntu Touch or even in Android.
How do I do that?
(08-07-2022, 08:57 PM)andrew907 Wrote: I am comfortably set up with a Pinephone running Mobian and a Bluetooth keyboard, but it would sure be nice to be able to see two apps at the same time like in Ubuntu Touch or even in Android.
How do I do that?
Currently there is not official way for doing that but you can try in terminal:
gsettings set sm.puri.phoc auto-maximize false
If I remember correctly that command allows the "windowed mode" similar as in Ubuntu Touch Smile
Not going to be perfect on phones screen but you can try and see
This will do the job, thank you.
  Screen auto-rotation sensitivity mdk 0 272 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 654 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,218 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 1,233 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,017 01-13-2023, 03:33 AM
Last Post: mdk
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,818 08-02-2022, 03:16 PM
Last Post: treebeard
  on screen keyboard woes vusra 1 1,251 07-18-2022, 03:29 AM
Last Post: vusra
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 856 07-17-2022, 10:34 AM
Last Post: 3x5co
  Won't boot, black screen mdk 4 2,739 07-03-2022, 06:38 PM
Last Post: Chief
  Disable *automatic* on-screen keyboard iwakura_lain 0 940 06-11-2022, 09:49 AM
Last Post: iwakura_lain
