Fedora 37 installation
I recently got a pinebook pro and have been playing around with distros to see what I like best. I found the existing instructions available for Fedora, but they didn't work for the 37 beta currently available. I had already installed Tow-Boot and that continued to work fine. Here's what I had to do:
  1. Boot from Fedora 37 live image. I used USB, but SD should also work.
  2. Run the 'Install to Disk' application
  3. Choose the install destination. I reclaimed all space on the emmc and installed there.
  4. There will be error boxes that pop up complaining about problems installing the boot loader. You can choose to continue with the installation.
  5. Once the installer has finished and before rebooting, you need to add a boot loader entry. I did this manually by creating a boot loader entry file here:
    Quote:/mnt/sysimage/boot/loader/entries/fedora37.conf
    With these contents based on the kernel and initramfs images I had present in /mnt/sysimage/boot:
    Quote:title Fedora 37
    options $kernelopts
    linux /vmlinuz-5.19.7-300.fc37.aarch64
    initrd /initramfs-5.19.7-300.fc37.aarch64.img
After rebooting, the system starts up with the newly installed Fedora 37. I also noticed running dnf upgrade created new boot loader entries for the updated kernel packages automatically and it starts up just fine.
Things I have noticed are not working correctly yet:
  1. Sound
  2. Does not wake up from sleep after either closing the lid or pressing the power button.
Fedora 37 installation - by gswatkins - 11-14-2022, 07:26 AM
RE: Fedora 37 installation - by poVoq - 11-14-2022, 02:43 PM
RE: Fedora 37 installation - by gswatkins - 11-14-2022, 07:23 PM
RE: Fedora 37 installation - by Shad0w - 11-17-2022, 08:36 AM
RE: Fedora 37 installation - by gswatkins - 11-17-2022, 09:05 AM
RE: Fedora 37 installation - by wdt - 11-17-2022, 11:07 AM
RE: Fedora 37 installation - by gswatkins - 11-17-2022, 12:04 PM
RE: Fedora 37 installation - by wdt - 11-17-2022, 04:30 PM
RE: Fedora 37 installation - by Shad0w - 12-15-2022, 08:40 PM
RE: Fedora 37 installation - by Rathann - 03-12-2023, 11:23 AM
RE: Fedora 37 installation - by poVoq - 07-06-2023, 12:11 PM
RE: Fedora 37 installation - by poVoq - 10-07-2023, 04:57 PM
RE: Fedora 37 installation - by jsch - 10-08-2023, 12:36 AM
RE: Fedora 37 installation - by poVoq - 10-18-2023, 07:53 AM
RE: Fedora 37 installation - by michel_luc - 12-10-2023, 10:32 AM
RE: Fedora 37 installation - by lovenemesis - 03-12-2024, 02:24 AM
RE: Fedora 37 installation - by michel_luc - 03-16-2024, 03:09 PM
  Fedora 36 -> 37 upgrade kills system tydeman 0 458 10-28-2023, 09:53 AM
Last Post: tydeman
  Upgrade Fedora from 37 to 38? acruhl 2 917 07-12-2023, 09:31 PM
Last Post: acruhl
  HOW TO create a installation USB with ... (see below) Ice-O-Star 1 1,166 01-06-2023, 01:02 PM
Last Post: DrYak
  My installation guide starting from messed up eMMC Besouro 0 873 12-19-2022, 01:01 PM
Last Post: Besouro
  Fedora Workstation (36) on Pinebook Pro u974615 13 7,330 09-02-2022, 11:24 AM
Last Post: u974615
  No audio on Pinebook Pro with Fedora? foobar 1 1,418 08-22-2022, 12:12 PM
Last Post: snorwood
  Fedora 33 to 34 upgrade issues tydeman 2 2,491 12-02-2021, 02:43 AM
Last Post: linuxfreund
  setting up fedora from minimal install pine76 0 1,336 11-30-2021, 10:47 AM
Last Post: pine76
Question Can't boot any operating system other than Fedora after following the nullr0ute guide TDC_PBP 1 2,451 10-09-2021, 07:35 PM
Last Post: TangoZuluTango
  Some little things to help Fedora users ccunix 0 1,595 05-22-2021, 06:32 AM
Last Post: ccunix
